Question about Pacific Image PrimeFilm 1800 Film Scanner
PF 1800 Scanner Silver--not scanning
I have had this PF 1800 silver slide scanner for a few years--it was working fine when I used it about 2 weeks ago. Today it pre scans/scans a slide--the mechanism is moving over the slide--but the resulting image in a completely white box. I reset all of the settings and then I dumped and reloaded the software but that didn't solve the problem. When I look inside I can see the low purple light  so I think the bulb is still working.  I took the lid off the scanner and blew it off with air. Then I put it back together and ran it--with the front portion of the cover up. I could see that the scanning mechanism was moving over the slide but the resulting image remains blank. What else might I try?
  • Hogenbirk Mar 28, 2009
    Excactly the same problem. I believe the light of the bulb is toob weak after a few years working. Question: can we buy a new bulb?
2 Suggested Answers
  • 100 Answers
SOURCE: PF 1800 Scanner Silver--not scanning porperly
the scanner assembly is getting blocked somewhere internally due to dust collected in the assebly.or it can be due to any of the wire internally gone loose or cut slightly so this problem.
Posted on Dec 25, 2008
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
How do you remove the top of the Magic Wand Portable Scanner to install the batteries for Vupoints model # ST415 magic wand?
The battery cover is the silver-colored "hump" on the right side of the scanner. Just slide it to the right, and it'll unhook from the scanner, giving you access to the battery compartment.
Oct 05, 2010 | VuPoint PDSST410VP
Sharps AL 1655cs have error L-3 and can not fix this? No manual Call 800 537 7464 or 321 951 0407 to help us. Carl Ring Melbourne FL. 329\04
L# means there is a scanner error. Most likely the scanner is not returning to the home position in time.
First do the obvious and see if the lamp itself is coming on.
Then remove the glass, and it is very common for that silver shaft toward the back of the scanner that the carriage drives on to become dirty and sticky.
Clean that shaft with alcohol or windex a few times. Then lubricate it with a light oil and slide it back and forth.
I would also look on the underside of the scanner. There is a latch, a scanner lock under there. See if it is in the locked position. If so, take a screwdriver and just pop it out and throw it away. It is only used for initial shipping. It isnt needed once the machine is in place.
I am 90 percent sure that either cleaning that rail or removing the scan latch will resolve your problem.
Jul 06, 2010 | Sharp AL-1655CS Copier
When the lamp is on, a clouded area appears on the underside of the glass platen. How can I clean it - or is this necessary? I believe I left the power on for a long period - did this burn the...
To open the Canoscan 8600 to clean the inside of the glass: Gently pry off the silver "c-shaped" trim piece on the front of the scanner. Slide the silver trim pieces on each side of the scanner forward and remove them. Gently pry off the remaining black trim piece on the front of the unit. This exposes 3 phillips head screws at the front of the scanner. Remove them. Pull straight up on the rear lid of scanner (where the 2 hinges are) to remove the top. This exposes 2 screws at the bottoms of the wells that secure the hinges. Remove them. Now the top is held by only 2 clips - 1 on each side. Pull up gently on the left side of the panel, front and back, and slide the panel back towards the rear. That should free the clip. Repeat for the right side. Take it easy, and you won't break anything.
Jun 21, 2010 | Canon CanoScan 8600F Flatbed Scanner
Document Type "Film" greyed out
Close Epson Scan, unplug the TPU, plug it in, turn off the scanner, turn it on, reopen Epson Scan.
Feb 16, 2009 | Epson Perfection 4870 PRO Flatbed Scanner
Unable to scan b/w neg's correctly using Digital ICE
Unfortunately, you cannot use Digital ICE on B&W films due to silver particles contained within the film. The Digital ICE future only works with C-41 (negatives) and E-6 (slides) processed films, but not B&W films.
Jan 16, 2009 | Nikon CoolScan V ED Film Scanner
Dec 25, 2008 | Pacific Image PrimeFilm 1800 Film Scanner
Epson V700 Photo Scanner
are you scanning it at the right resolution and are you using the negative holder?
Nov 09, 2007 | Office Equipment & Supplies
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Pacific Image PrimeFilm 1800 Film Scanner Logo
428 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Gene Tuck
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
