Question about Toshiba 56HM195 56" Projection HDTV
Green/Pink Screen I have had this TV for about 7 months and haven't had any problems until now. I now have a greenish screen at all times. Has anyone else had this problem? Does anyone know a solution?
  • Bill_W Apr 18, 2007
    Thanks. It stopped for a few days, now it is doing it again. Yes, it is on all inputs. I don't have an HD cable box, I have a cable card. I will check all of the connections. Thanks again.
    President:
  • 1,284 Answers
Is this on all inputs? Have you tried unplugging the set for 2 minutes then trying it again? Did you check all of the connection ong to the set such as component cables leading to a HD cable box? If so then the parts should still be under manufactures warranty.
Posted on Apr 18, 2007
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
I have a 50inch DLP Hitachi that is 3 and a half years old. I replaced the bulb about 5 months ago now the blacks are blueish and it has a greenish blotch on the screen. It also leaves an image on the...
Contrary to popular belief, any display product can have "Image Retention" and even "Burn-In". This is true for Plasma, LCD, LCOS, DLP, and CRT. I do not see a model number provided, but I would bet that you have an LCD rear projection TV rather than a DLP projection TV. If this is the case, the Blueish and Greenish blotches you are seeing on the screen are the result of UV light damage. UV light will move heavily damage the Blue panel, due it's short wave length. So, bad Blue or Green (absence or Blue) is typically the the first visual indicator of a problem. Replacing the Light Engine will resolve the problem.
Mar 15, 2010 | Hitachi 43FDX01B TV
Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
TV KOLIN 21"
hello.... do you have any speakers near your television? what color is the circle your talking about? Do the green,pink colors are scattered all over the screen and specially on the corners?
If you have or had speakers near your tv? then do this try to get a magnet.a magnet on a speaker would do.what you have to do is to place the magnet near the screen of the tv approx. above the green,pink color (turn it on first).you will notice the that the color will react with the magnet try to pull it on the side you will notice that the green,pink color is moving on the same direction do it until its gone.NOTE make sure youll not scratch the screen ok.email me what happened. jaredreyesbalderama@yahoo.com GOODLUCK
Jan 21, 2009 | RCA 20F512T 20" TV
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Greenish color whole screen
THERE IS APROBLEM IN VIDEO SECTION.OR CRT TUBE .REPLACED CRT BASE AND GREEN CATODE TRANSITOR OR WHOLE BASE IT WILL WORK OK
May 20, 2008 | Memorex MT201224 20" TV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Green spot on the screen.
is there a speaker from a stereo player near the set? i noticed mine give my tv a greenish tint on the side of the tv closet to the speaker
Aug 05, 2007 | Sanyo HT32744 32" TV
Toshiba 56HM195 56" Projection HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
