Question about GE 97985 Mouse
Does my ge wireless optical mouse works?
I mean when i plug the receiver into my notebook starts binking but the mouse just still the same and so the cursor it doesnt move when the mouse get slid how can i make it work?
  • t_erry10 Dec 26, 2008
    i found the button you said but i pressed a few times i even did for a long time but there was no diference
    i think i should better replace it
  • Anonymous Feb 19, 2009
    frequently the mouse will not work
  • 741 Answers
Look on the bottom of your mouse. There is a off and on button make sure it is turned on.
Posted on Dec 26, 2008
  • Randall  Trahan
    Randall Trahan Dec 26, 2008
    Ok final try, is the battery working inside of your mouse..
Do I need a receiver plug-in for my Gateway laptop to use a GE wireless optical mouse model 98763?
Garrett, Yes, plug in the receiver that came with mouse. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Wireless Mouse and Driver Problem Fix
http://techin.oureverydaylife.com/ge-wireless-optical-mini-mouse-stepbystep-setup-13706.html
GE 98796 Wireless Optical Mouse Manual
Aug 22, 2016 | Gateway Computers & Internet
GE wireless optical mouse suddenly stopped working. i restarted computer and tried to reset both mouse and the receiver to no avail. also changed out batteries.
Hi, my mouse work fine since pressed simultaneously the buttons of the mouse and the receiver. Previously, I had disarm the receiver, but all was fine, so I'd arm again the receiver and plug to laptop; I'd press both buttons and mouse work. For any reasson, mouse and receiver lost conection and is necessary re-establish comunication pressed both buttons. I hope my experience (my case) to be useful to someone.
Jun 24, 2010 | GE Wireless Optical Mouse
I have a GE wireless optical mouse that has decided no to work
I had the same problem till I discovered there are two buttons (not just one) you have to push to re-link the mouse and the USB receiver. Plug the little receiver in, push the tiny "connect" circle on the receiver (which is actually a button I guess), then wait for the red light to start blinking. Then press the little link button on the bottom of the mouse.
Jan 18, 2010 | GE Wireless Optical Mini Mouse 3087897985
GE Mini Wireless Optical Mouse HO98763
Did you try pushing the link button on the bottom of the mouse (right after pushing the connect switch on the receiver?)
Sep 03, 2009 | GE Wireless Optical Mini Mouse 3087897985
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Jul 30, 2009 | GE Optical Mini Wireless Mouse 98793
Maybe mouse maybe vista maybe Toshiba
check the mouse for batteries. Plug usb receiver into the usb plug. Turn mouse over and make sure switch is in the "on" position. That should do it..if not any questions you have let me know..
Pls rate this solution.
Apr 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Hi, I bought the new wireless optical mouse of ge.  I lost my owner's manual and don't know if I have all the parts.  Do I just need the mouse and my apple macbook pro to make it work.  can you tell me how...
The GE mouse came with a Receiver that goes into a USB port after the CD software program is installed. During installation the program will ask you to plug in the receiver into a USB port. This is when to do so. Then it should work properly.
Jan 20, 2009 | GE Wireless Optical Mouse
GE 97985 Mouse Logo
255 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
