Question about Radio Shack Cinego D-1000 Multimedia Projector
Projector will not recognize my VCR
I cannot get the projector to recognize my VCR.
  • 2,237 Answers
What inputs are you using? make sure video is selected on the projector and that it's running hd or not.
Posted on Aug 19, 2009
Projector no longer recognizes computer
i would google master reset for your device. it involves holding buttons down
Mar 11, 2014 | Sharp Office Equipment & Supplies
Projector Image Cut Off, Native Resolution Not Recognized by PC
after you connect the laptop and the image shifts to the right, press auto adjust on the remote and the image will get OK.
If not try resetting the projector settings to factory [not the lamp settings]
this should solve the problem
if not change the main board
Jan 15, 2013 | Panasonic PT-AE900U Multimedia Projector
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
Only get black and white from the Video on VCR; get color on computer. Have taken VCR to another proxima and it works have also tried different audio cables, but no change.
on the User Menu of the projector, make sure NTSC is selected when on the Video option of the projector, or you can have it set to Auto.
May 23, 2011 | InFocus Proxima UltraLight LS2 Multimedia...
Projector is connected to an HP laptop. Once everything is plugged in and the projector is turned on, I turned on laptop as per the manual. The projector recognizes the device, shows the HP start up...
Press Fn + F4 keys, it will change output to external monitor.
Toggle keys to get needed combonation: projector only -> Projector+Laptop screen -> Laptop screen
Mar 09, 2011 | Dell 2300MP Multimedia Projector
I have hooked my Epson 77c to cable in the following method. Cable directly into old vcr, vcr cabled into tv, RGB cable from vcr out to Epson 77c video input. The issue is that I can view only channel 3 on...
VCRs typically do not have RGB outputs. If you are using the VCR as a tuner for your projector, then be sure you have selected the VCR/TV button to VCR then your VCR will be the tuner. If you have it set to TV then the signal is passed through the VCR by your coax to the TV and the TV is the tuner but the VCR is now only outputting Channel 3.
Feb 22, 2011 | Epson PowerLite 77c Projector
How to hook up cable from the wall to epson ex30 projector
The Epson is a monitor only. It has no tuner, so no cable connections. If you have a cable box or VCR, or DVD with RCA Style Connectors (yellow, red and white) connect your cable coax to the box or VCR and then the video and audio outputs on the box or VCR to the projector and select the video mode.
May 28, 2009 | Epson Televison & Video
How do I hook my data projector up to my cable TV?
If the TV offers video and audio outputs, you can connect those to the projector. Otherwise you'll need to use a VCR or DVR as the source. In fact, you don't need a TV set at all if the VCR/DVR you use has TV tuning. Hook the video to the projector, run the audio through your stereo system and you're set.
Jan 28, 2009 | Sanyo DS25390 TV
MacBook Pro (Leopard) doesn't regconize the projector when on (No input)
You must make sure the Mac resolution is set to 1024 X 768, otherwise it won't be recognized by the PG M20X Sharp projector. This change in resolution will cause the screen size to get smaller on the mac but, it will allow the projector to recognize the computer.
Sep 10, 2008 | Sharp Notevision PG-M20X Multimedia...
Projector turns off after 35-40 minutes
i have the same problem with my projector it sudden turns off, and it has a blue stipe on the bottom of th screen. is this a sign that my blub is bad? or is it the power supply that is damaged? it can be on for days without any problems and then they come and go..
Mar 12, 2007 | Canon LV 7345 Multimedia Projector
126 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Tom Chichester
Colin Stickland
Colin Stickland
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
