Question about Harman Kardon AVR 225 Receiver
AM/FM receiver The radio is not functioning properly intermittently. I can some times receive both AM and FM, but sometimes only AM, sometimes nothing at all. There is never any additional static that would be normal. All other source inputs work fine. When I can receive the AM only, I cannot change the station. The display will change when I push the tuning button to another station, and the display will switch to FM when I push that button as well, but the tuner will not change from the initial station.
  • Sacjazz Mar 17, 2008
    My receiver acts as if it's not receiving a signal, everything else, including the speaker hum, works.  For a long time, the receiver would work as long as I didn't turn the power off, it was ok if I went to other channels, but now receiver doesn't work at all.  The readout, and everything else still works.
  • 38 Answers
The problem is in your tuner for me it is betwen the IC and the IF transformer. if u cant fix it buy new stereo componet.
Posted on Apr 18, 2007
I experience a problem with the unit in radio mode. When switched on the radio do not latch on the station (only background hiss) Only after repeatedly toggling the BAND button (random times)it will l
Try turning off the AutoTune (lock, center....) function (on most FM tuners) and retune manually to the errant station. Then reactivare auto-tune, or not. Toggling bands (as you put it) means that sometimes signal will center, sometimes not...a more or less random thing as you say. That suggests resetting station auto lock. Bear in mind though that certains stations can simply be uncooperative depending on numersou factors such as transmit location, reception terrain, and so on.
Oct 03, 2014 | Crosley CR7002A Turntable
My radio reception is intermittent
Check your antenna and antenna cable. Many devices has switching power supplies with can interfere with the receiver like a computer, laptop, dect home phone, printers, fax etc. Also could be something outside like rf tower. you may try other receiver/fm tuner to see if it has the same recption problems. If you find that your receiver is no good you need to replace internal FM tuner.
Dec 08, 2011 | Denon Audio Players & Recorders
Why can't I receive AM or FM radio
check the aerial is plugged in properly at the back of the radio
Mar 12, 2011 | Jensen MCDA1 AM/FM/MP3/ Stereo with...
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
I have a 1999 Cadillac DeVille Concours with an AM/FM/Cassette/CD/RDS Radio. The AM works fine, the FM does not, screen shows digital info(stations like 99.3, etc) but no sound. RDS does not function at...
Well there's lots of possible reasons. The FM receiver portion of the radio is separate from the AM Band receiver, pre-amp, and amplifier sections of the radio. The FM receiver may have simply failed, as well as the CD player portion of the radio. Your car FM needs repair, you need a multimeter to check it or take it to a repair person. Please post further comments for further help or information......
Good Luck!!
Thanks
Jul 06, 2010 | Car Audio & Video
My 2000 Toyota Solara radio has started to lose a strong signal.
Check mounting surfaces at antenna. Corrosion or looseness and the antenna loses its ground to the body.
Oct 27, 2017 | 2000 Toyota Camry Solara
No AM or FM yet cd player works
Friend,
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Mar 06, 2008 | Sony XPLOD CDX-GT200 CD Player
Poor FM reception
The Phone must be on.
The SIM card must be a valid one.
The station you listen to and the network operator you use, must support the service.
The headset or enhancement needs to be attached to your phone. for the FM radio to function properly, it's an aerial as well as a headset.
Therefor if you are in a poor reception area for making/receiving calls it will also affect the radio signal.
Jan 13, 2008 | Nokia N73 Cellular Phone
No reception sometimes
Either this is typical shortwave reception characteristics, or you intermittent antenna connection.
Sep 23, 2007 | Sangean ATS 808A AM/FM/SW Radio
Harman Kardon AVR 225 Receiver Logo
343 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
