Question about Belkin (F5D7230-4) Router (587009)
Security enable need to turn security off so wireless can long on..
  • 827 Answers
Just go to the connections in your wifi list and double click on your router, and enter your username and password.
You can Click the Automatically connect to this Network button too.
Otherwise, you can put 192.168.0.1 into your internet browser URL address bar and hit enter. This is the router's local IP address. Go to security and Disable WEP or WPA or whatever encryption is enabled.
Hope this helps
Chris (ziraffa)
ps also make sure the 'Wireless' button is clicked on your laptop and the blue wifi light is on!
Posted on Dec 26, 2008
  • chris grams
    chris grams Dec 26, 2008
    Actually I think I meant to type 192.168.2.1
    Try that first! Sorry!
    Chris (ziraffa)
Wifi is turned off. How do I turn it on?
Stuart,
Some NetGear routers have a wireless button to enable/disable the wireless feature. Look for a wireless LED on the front of the router, if it is off check the back of the router for a wireless button. Press the button for 5 seconds to turn the wireless feature on/off. If that doesn't work you may need to login to the router to enable the wireless feature. Here's a snipet from the NetGear knowledgebase:
1. Type http://192.168.0.1 or http://192.168.1.1 in an Internet browser - some routers use the first URL while others use the second. If one of these does not bring you to the router's login screen, see If You Cannot Log on to Your Router.
2. Enter the user name and password; the defaults are admin and password unless you have changed them. NETGEAR strongly recommends changing the default user name for your network security.
3. Check Wireless Settings > Advanced > Enable Wireless Router Radio. For newer routers with a Genie interface, click on the ADVANCED tab > Advanced Setup > Wireless Settings > Enable Wireless Router Radio.
Note: You will need to uncheck two separate Enable Wireless Router Radio box if your router is dual band. One for the 2.4GHz and one for the 5GHz network.
I hope this helps.
Mar 15, 2014 | NetGear N150 / RANGEMAX 150 Router
How to connect to wireless internet
First, read about connections here:
http://www.fixya.com/support/r5536767-internet_connection_basics
Once your wireless router is connected and the wireless mode enabled, your computer that is wireless-enabled will see the wireless connection. You can select it and then click "connect."
This assumes several things:
1) you have a wireless router and it's set up correctly
2) you have a computer that is capable of connecting wirelessly
3) your wireless adapter is turned on (there is usually a switch or a Fn-special function key combo that can turn you wireless adapter on and off
4) you know the password to get into the wireless connection.
Jun 20, 2011 | Acer Aspire One PC Notebook
How do I enable wireless security on router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Jun 25, 2010 | D-Link DIR-615 Wireless Router
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
What settings do I put into my laptop to enable it to wireless?
did you turn on wireless some laptops only need to press fn then it should find any wireless networks and if you router is security enable you need the pass word from your provider or sometimes it is on thew bottom of the router
Jan 15, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
WRT54G router working fine but need to turn on security.
with the wrt54g you need to open a internet browser and navigate to 192.168.1.1
a security screen will pop up to which the username is "admin" and the password is either "admin or blank, (unless you specified otherwise when running the install.
once in click wireless then security in the sub menu (under the wireless link you just clicked) then fill in the boxes
Mar 01, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Trying to connect new printer wirelessly, cannot get past the wpa security key
You may need to verify the wireless security enabled in your router. Check from your router's setup page the security type and security key enabled in it to connect your wireless printer.
Hope this helps!
Nov 13, 2008 | HP Computers & Internet
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Losing wireless connection when I enable wireless security on 2350
Have you tried your laptop on a different wireless network?
Apr 27, 2008 | Dell Wireless 2350 Router
Belkin (F5D7230-4) Router (587009) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
