Question about Uniden BCT8 Base Scanner
Cannot plug the antennae in for home use
Cannot hook up antenne to back of BCT8 scanner, It will not fix in the back plug How do I fit it in?.
    Problem Solver:
  • 5 Answers
You may need an adapter. I had on come with my scanner.You should be able to get one a a dealer who sells and services scanners
Posted on Dec 27, 2008
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
Reset bct8 back to factory settings
Turn the scanner off, then hold down the 2 , 9 and HWY (State) button....all three at the same time and then turn the scanner back on. This does a full reset to factory settings.
with radio off, press and hold 2, 9, & hold button, then turn on and hold all three for at least two seconds to reset.
With the scanner off, firmly hold down 2+9+State at the same time while turning the scanner on. (You may have do it several times) When you see (Clear)
its reset.
Dec 24, 2013 | Uniden BCT8 Base Scanner
Have a BCT8 in my 2000 Dodge Ram 5.9L cummins. Got antenna and scanner grounded4, but seem to get a lot of stactic. Got any good ideas? How about wire to battery?
hello this could be caused by the transmission from the dodge you can buy suppressers that will eliminate this problem or place a resister across the power terminals ,second solution turn squelch fully clockwise hope this helps goodluck
Apr 19, 2011 | Uniden BCT8 Base Scanner
.........i want to switch my scanner over to
Sorry, but the Uniden Bearcat BCT8 is an analog-only scanner, and there is no magic that will enable it to receive and process digital signals. EDACS, however, is NOT a digital system. It's discussed at length in the BCT8 operating manual, which also contains step-by-step programming instructions for EDACS systems. You can also find a lot of useful information on EDACS, and specifics on systems in use in your area, at: www.RadioReference.com
If you don't have the manual for your scanner, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BCT8om.pdf
Bill B.
Listening in since the 60's
Jan 18, 2011 | Uniden BCT8 Base Scanner
Is there a Master reset feature for the Uniden Bearcat BCT8 scanner? Need to reprogram and start from scratch. See nothing in the manual on how to perform this function.
turn off scanner hold down the state/highway the number 2 and 9 then while holding the 3 buttons turn your scanner back on while holding the state/highway, 2 and 9 buttons if you did everything correct you will see a clear message show up and about 2 seconds later hear a beep
Oct 24, 2010 | Uniden BCT8 Base Scanner
Cant seem to get it to pick up local frequencies
Can't really diagnose the problem without more information, but make sure that your antenna is connected properly and that you've programmed frequencies that are active in your area. For a quick function check, program the frequency 162.55, 162.4, 162.475, 162.425, 162.45, 162.5, 162.525, 161.65, 161.775, or 163.275 into your scanner. One of them, probably the first one, will be the primary weather frequency in your area. If the scanner picks up the weather broadcast you'll know that it's working.
Dec 28, 2009 | Uniden BCT8 Base Scanner
Wheres the antenna?
Hi i'm Ryan, the antenna should be located in the rear window (glass-integrated FM diversity antenna) It should plug into the back of the radio, not sure if you can use that location instead.
Dec 31, 2008 | 2003 Lexus ES 300
Programming error BCT8 Uniden
Hello.
Back to answer my own question.
I just found the problem. If you try to program one of these scanners (Uniden BCT8) and you keep getting a "pr9-loc" message every time you try to enter a frequency and "M-LOCK" is showing in the upper right corner of the display press and hold the M-Lock (E) key until it beeps twice and "M-LOCK" disappears from the display. You're now set to program.
Keith.
Dec 30, 2008 | Uniden BCT8 Base Scanner
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Uniden BCT8 Base Scanner Logo
157 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
