Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
Lamp replace the lamp with a new one and still have the lamp light flashing samsung 61 in tv hlp6163w lamp bp96-00826a[p]
  • matthewquigl Dec 26, 2008
    did that
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    check lamp cover as it seems not fixed properly and causing lamp error.
  • 185 Answers
You might need the ballast as well
Posted on Dec 26, 2008
  • A Schneider Mar 05, 2009
    yupe if the lamp isn't installed correctly then you will gt an error, is it sorted out now?
The screen on my Samsung DLP tv turned off with the volume still playing. The lamp light started flashing. We replaced the lamp and it doesn't seem to have fixed anything. What could be wrong?
Lamp Fan could be defective or the Ballast Board ,it is what powers Lamp.
Encompass Parts Distrubution 1-800-638-3328
Go to this website and type in your Model# for list of Parts /Prices
Oct 07, 2010 | Samsung HLP6163W 61" Rear Projection...
My TV turns off by itself. It is a Samsung HlP6163W. Service Model HLP6163WX/XAA. The two green lights flash at the same time. I think it is overheating the bulb. How do I fix it.
Lamps don't really last very long typically 1 to 3 years depending. You may just need to replace the lamp. A burner gap of a lamp expands as the lamp warms up. If the gap is too large due to age (normal usage) the lamp will fail to light or shut down once the expansion occurs. The solutions to either problem is to replace the lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
I have a Samsung TV # HLP6163WX/XAA. A loud humming sound started and the picture went to black and white. The green "Lamp" and red "standby/temp" lights are flashing on front of the tv. Any ideas on the...
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Jan 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Lamp light is on. TV wont turn on?
Lamp light is On that means lamp is dead and requires replacement.
How old is this TV and did you replaced lap recently?
Lamp replacement procedure would be written in user manual.
Thanks.
Nov 26, 2009 | Samsung HLP6163W 61" Rear Projection...
We have a tv turning on then off and states it is overheating
You don't mention if you get a picture or not but you might want to check the lamp for signs of damage. I think you will want to check samsung's website samsung.com/support and type in your model, some of these model are experiencing similar problems and there might be a firmware update for this.
Sep 09, 2009 | Samsung HLP6163W 61" Rear Projection...
3 flashing lights after replaing lamp
check the lamp connection and also to insure you have the correct replacement lamp for your model. as 3 blinking LEDs mean lamp may be defective.
May 25, 2009 | Samsung HLP6163W 61" Rear Projection...
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP6163W wont turn on
I went to sleep my tv was play i woke up and don't work so i turn it on popping crack sound and it shut down what do nowno tv
Sep 13, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Blank Screen Problem
Does the menu come up? If it does, then, the source could be the problem, such as the cable or DVD player. If the source is not the issue, then, the problem would be in the Digital or Analog PCBs. If the menu does not come on, then, the problem is more than likely the DMD. If it is not the source then call a local authorized Samsung servicer in your area. Contact 1-800-Samsung. Hope this helps.
Apr 01, 2007 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
294 people viewed this question
Jerry Greenberg
Jerry Greenberg
