Question about Disney Pix Micro Digital Camera
Is the camera suspose to beep when taking a picture?
The camera just barely beeps when button is press to take a picture. Then it beeps three more time. When you download the camera, all you get is a black box, some you can just barely see an image.
Yes it is sposed 2 beep when you are takin a pic. too tell u its done taking.
Posted on Dec 26, 2008
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
How do you delete the pictures, so that you can take some more pictures.
On the back of the Camera there is a "Delete" button, that has a picture of a Trash Can on it. Press and hold this button for 1 Second to delete the last picture taken. You should hear a short beep. To delete al the pictures off the camera, Press and hold the delete button for at least 2 seconds.You should hear a longer beep sound as confirmation.
Dec 28, 2010 | Disney Pix Micro Digital Camera
I press the button to take a picture. You get the beep beep, but it will not click and take the photo
Clean camera lens, let it focus on any item after that press half finally fully press the shutter.
Feb 23, 2010 | Canon PowerShot A620 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Problem with image
What mode is the camera in? is it in "Auto" at the top there is a dial switch it to auto and press button halfway (shutter button) when you press the button halfway the camera will beep and display a square box on the LCD. If the camera beeps once and the box is orange it could not focus and you need to retry pressing halfway again. When it is in focus it will beep 2 times and it will show a GREEN box. This is the indication it could focus on the subject correctly. Its a machine and sometimes it takes it a bit for it to figure out what your wanting it to do. Its the nature of the unit
Apr 03, 2006 | Canon PowerShot A85 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Disney Pix  Micro Digital Camera Logo
64 people viewed this question
Top Disney Cameras Experts
mohamed salim shaikh
James Woodgreaves
James Woodgreaves
Are you a Disney Camera Expert? Answer questions, earn points and help others
