Question about Sony VPL-ES1 Multimedia Projector
Blue tinting appearing on the right side of screen on vpl-es1 projector
I have a blue tinting appearing on the right side of screen on vpl-es1 projector. It appears to be changing shape on a daily basic. I have also notice a slight burn in of a tv show logo in the same area. Any thoughts on how to fix this would be helpful. John
  • John Frame Jun 28, 2007
    Its more of a blue blob that was moving around and now takes up about 1/3 of the screen. When there is a channel logo at the bottom it will leave a faint ghosted image of that logo behind after the actual logo is gone but it will soon fade away. I will try to post a photo of the screen soon.
  • jamestct Sep 25, 2008
    We have a few of these in the school where I work and one of them has developed this nasty blue blob fault as well. I thought it was the bulb but when I swapped it out the problem remained.
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
Posted on Jun 28, 2007
My projector shows a blue tint to the right of the screen. I am afraid that it might be the blue LCD panel gone bad. What might the diagnosis be? Sony VPL-HS51
Does the blue tint show up as small rectangular pixel shapes when you get up close to the screen when focused properly. This would indicate a blue LCD panel fault. If it's fuzzy then possibly a blue polarizer overheating
May 14, 2011 | Sony VPL-HS51 Multimedia Projector
Patch of purple "scribble" lines on corner of screen
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Aug 01, 2008 | Sony VPL HS10 Multimedia Projector
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Jan 30, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Sony VPL-ES1 projector
Hi Max
Is there any power on the unit at all ?
i.e. Does the LED's on the unit indicate that it is in stanby ?
If it isn't then it could just be a fuse that has gone on your Powersupply.
Apr 21, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Apr 16, 2008 | Sony SuperLite ultracompact Project...
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Purple and green and shaking....
Hi guys
You will have to replace the LCD's .
Must warn you that it is very expensive
Dec 07, 2007 | Sony VPL CS1 Multimedia Projector
Sony VPL-ES1 Multimedia Projector Logo
491 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
