Question about Air Tools & Compressors
LEAKING BOSTITCH AIR NAILER
THANKS FOR THE INITIAL SUGGESTION. THE MODEL IS N80SB-1
THANKS AGAIN, ED I have a Stanley Bostick finish nailer (N60FN) that leaks air near the trigger. Can anyone help?
  • MVSSR Dec 26, 2008
    I will check the color, thank you for the help.
  • 21 Answers
You probably have a trigger valve that is green. if so then it will have to be replaced, the valve runs about $ 20 but you can put it in your self.
Posted on Dec 26, 2008
Where can i get parts for n 60 nailer
Bostitch was purchased by Dewalt and parts are available from your local Dewalt service center or here:
http://servicenet.dewalt.com/
Good luck.
Jul 16, 2014 | Stanley Piston Driver Assy Bostitch N60fn...
Stanley Bostitch N60FN finish nailer only pops when the trigger is pulled.
replace broken driver, or if driver is not broken replace the oring on the driver piston
Sep 10, 2012 | Stanley Air Tools & Compressors
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
My N80SB nailer all at wonce started leaking air some where near the triger and wont work. Could you tell me what to do? Thanks Tommy
Most likely the "O" ring seal has given way for some reason. If your not experienced in repairing this type of equipment, considering how dangerous a misrepaired tool like this can be, I recommend taking it to a qualified repair tech. Double check your purchase date it may still be under warantee.
Jun 12, 2010 | Stanley Bostitch N80CB Coil Framing Nailer
I have a Stanley Bostitch finish nailer n60fn its leaking air from the trigger and housing.Is this something that I can rebuild and if so where can I get the information on how to rebuild it?
The fix it replace the trigger valve. It is a 5 minute job and seems to be a pretty common problem. Bad news is they seem to run about $30. I believe the bostitch # is TVA6
Apr 04, 2010 | Craftsman Nailer Kit, Palm Air Driver
Fires like a machine gun without pulling triger. Close call
Bostitch N60FN finish nailer:
I replaced the o-rings and reassembled now when I put air to it the driver does not return and when I pull the trigger I get a "puff" sound.
Sep 07, 2009 | Stanley Bostitch N88rh Framing Nailer...
My N60FN is leaking from around the trigger, where can I purchase a re-build kit?
The whole trigger assembly must be replaced.
http://www.mastertoolrepair.com/n60fn-p-4155.html
Jul 23, 2009 | Stanley Bostitch N88rh Framing Nailer...
N80sb-1 stanley bostitch framing gun.
try going to their website -I have several guns and each take at least 4 sizes of nails- yours should be no different- good luck hope this helps
Oct 11, 2008 | Stanley Bostitch N86S 1 Factory...
Your welcome. Todg, has a rude way about him, but he's pretty new and his numbers aint so great.
A lot of people forget to include a model number and we can only guess until we have it.
Are you still in need of help?
Worldvet
Sep 29, 2008 | Air Tools & Compressors
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Air Tools & Compressors Logo
452 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
