Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
Hard Disk Quantum QML20000LD-A
I need to repair a Quantum hard disk (QML20000LD-A) with some important data on it. I have found the electronic demaged, one smd resistor was broken and lost, so I'd need to know the value of this resistor to replace it. Where can I find some electronic schematics of this hard disk.
    Brigadier General:
  • 6,966 Answers
Hi, may I offer an alternative solution? You may want to try and replace the entire PCB assembly rather than repair. I would assume that the Quantum QML20000LD-A is a few years old and so many of the same brand/model would be lying around computer repair shops. Even if defective, these drives can be: 1) direct parts source; and 2) remove/use the entire board. You can even find this kind of HD from old CPUs (166-550 MHZ.) I believe you can get them relatively cheap and faster. Hope this somewhat helps. Cheers.
Posted on Apr 17, 2007
  • Louie  Role
    Louie Role Apr 26, 2007
    Hi again, just curious, were you able to get hold of the schematics?
Dear sir I have a HDD 20 GB fireball and I have problem with it in the low speed of read and write in operation. I instaled windows XP and I want to improve speed my HDD. please advice me about this...
Its a very old hard disk, few things you can do,
1.. Get into your pc's bios and see if 32bit access is enabled for your disk, if not enable it, reboot.
2.. Goto control panel > device manager , double click on your IDE controller and check had disk status, if is on PIO mode or UDMA , must be at UDMA. Set it if not.
Jul 29, 2011 | Quantum Fireball Lct20 (QML20000LD-A) 20...
MI DISCO DURO SUENA COMO
Not a good sign. You will need to pay to have the data recovered if you need it. Otherwise, plan on getting a new disk and reinstall Windows.
May 22, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
My harddisk do not ditect, i have tried very much.
i suggest make your hard disk to be slave..then you can copy what important file in that hard disk and save it to the other hard disk..
try to connect it to others pc with master hardisk tha runs good..then you will see if your hard disk still works there..if you can't open it..you may have corrupted or bad track disk..or maybe worst.. you hard disk is damaged...
Feb 08, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
My maxtor 500GB sata hd gives zero number of cylinders
go to the bios system
select booting device
choose hard disk
save & exit
thank you
Jan 15, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard disk not recognized
found the solution inside Dell web page - jumper position shown graphically - Thank you, anyway.
Jan 07, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
The board got burn on one of the chip
You have two separate questions.
1. I have a Quantum hard drive which got a burn on one of it chip on the green part it is from an IBM aptiva 95 all of my data is on it .
Unless you can find an _identical_ hard-drive, and disconnect the electronics from that disk-drive, and then connect the electronics to your hard-drive, your data is "lost". Or, find a "Data Recovery Service" -- for a large fee, they will repair your disk-drive, just long enough to burn a bunch of CD/DVD disks to hold all the "data".
2. I have onother that I have accendentally delete one of the partition which is the C drive
Download the "Partition Tool Editor" by the PowerQuest PartitionMagic people (now owned by Symantec):
ftp://ftp.symantec.com/public/english_us_canada/tools/pq/utilities/ptedit.zip
Unzip the file, and, while the "accident-prone" disk is connected ot your computer, run 'PTEDIT.EXE' to change the Partition Boot Table, to "undelete" the partition. It's *NOT* a tool for "novices" -- think carefully before making any changes to the Partition Table.
Nov 20, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Does the Intel 82801 chipset recognize the full capacity of a quantum 20gb hard drive?
Yes it should recognize such small drive. Note that the partitions on the drive will affect how big drives are shown.
If the drive is partitioned into two 10GB parts then you should have C: 10GB and D: 10GB
Note that if the drive is partitioned not to use the full capasity then the capasity it is partitioned to will be shown instead.
Also Note that computer hard drives the capasity is not accurate presentation of the GB available. it will always be somewhat less than the reported size, for example 1000GB disk is shown as 931.50GB
500GB disk is shown as 465.76GB and so on.
see picture:
Jul 29, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
How to format low level format
You can download a software named Disk Manager from Seagate website and then write the program on to a CD, boot the computer using a Windows 98 bootable cd and then insert the Disk Manager and open the program, you will get the options to low level format
Rergards
Ajesh,
Professional Virus Removal Expert
Jun 19, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
654 people viewed this question
Top Quantum Computers & Internet Experts
Marvin
Marvin
John Porter
Alun Cox
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
