Question about SanDisk Sansa Clip MP3 Player
Sansa clip menu is not in English
Or in any dialect i understand. The menu is all in odd characteritures that resemble different things.
  • 8,596 Answers
Download the Sansa Recovery Tool to get the ****** back to normal.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
My sandisk is displaying a language I do not understand and I do not know how to change it back to English
Your problem is problem of other people too and the step by step solution is available on the manufacturer's web site here
This instruction is valid if you have really Sansa Clip. (not Clip+)
Thanks.
gylacz
Sep 19, 2011 | SanDisk Sansa Clip MP3 Player
How do I get the language back to english on a sansa clip
To get back to English on a Sansa Clip:
1. Start from the main menu:
> Press the menu/home button
2. Select Settings [ image of an equalizer ]
> Press the pauze/play button >|| several times to select the equalizer
> Press the center button to enter the settings
3. Select language
> Press the Down button to see an option with the letter FM
> When you see the FM option, go one step upwards with the UP button: this is the language option
> Press the center button to go into the language selection
> Scroll Down/Up through the options to find English
> On the preferred language press the center button to select it
Aug 15, 2010 | SanDisk Sansa Clip MP3 Player
LANGUAGE IS NOT ENGLISH
It was your setting. You can change it to english.
For sansa clip:
1. From main menu, select settings (picture with 4 bars)
2. Use up/down button to find " FM...", the language option is right about FM..., select it and use up / down button to find English.
3. Press home button to come back main menu
Good luck
For sansa clip plus:
1. the same as about.
2. Getting into Settings, you have 4 options (Music, Audiobook, Radio, and System Settings). Languages with letters (a, b, c, ....), you can see "Radio...." option, move the selection bar down 1 - it is System Settings. If Languages without letters a, b, c, ...., you have to get in to each option, at each option you move the selection bar down or up to find letters " USB...." , it means you are inside System Settings, from USB, press down button 6 times, and select it (language option), scroll up/ down to select English.
3. The same
Good luck
Feb 04, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip plus 4 GB is not in english how can I change it so it is?
From main menu, select Settings (picture with 4 bars), find FM......, then go up ONE and select it (this is language), you can go up or down to find English language.
Good luck
Dec 28, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wrong language
Go to the settings menu, or whatever "settings" is in the language you've got it in and keep opening different stuff in the settings menu until you find the list of languages. Go through the list until you find "English." It might be spelled slightly differently in the language that it's in right now, but you'll be able to tell which one it is. Select it and the language should go to English.
Aug 17, 2009 | SanDisk Sansa Clip MP3 Player
Language is in Indian cant understand to change it back to english
Press Menu button to return to the Main Menu.
Move to Settings and select it.
Select Language.
Select a desired language.
I found my answers here: http://www.sandisk.com/assets/file/downloads/user-guides/clip-usermanual.pdf
Apr 19, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 1gb mp3 player
You will have to fly blind a bit, but remember that the Spanish word for language is "idioma" and the Spanish word for English is "Ingles" - Here is a link to the user manual that will help you - Sansa does have a Spanish version of the manual if you want to compare. Eventually, you want to find this menu/setting:
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa m240 MP3 Player
I can't read the menu to change my player back to english.I need help to navigate through the menu to find settings. pLease help!
Use the following manual to help you "fly blind" and change the language back (or do an English firmware upgrade from Sandisk's website):
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 25, 2008 | SanDisk Sansa Clip MP3 Player
Need change option
I don't quite understand your question, but the user manual has all the answers:
-Tha Mp3 Doctor
Dec 06, 2008 | SanDisk Sansa Clip MP3 Player
Sansa mp3 player stuck on different laguage
For the Sansa Clip:
Turn device on
Scroll to Equalizer looking thing (box with 4 sliding levers)
This is the settings function Select it by pushing middle button
Hit the scroll down button 3 times or scroll to the option right above the one that has FM
Scroll up or down until you see english
Good Luck
Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
