Question about Panasonic SC-PT960 Theater System with Wireless Speakers
Wireless pananaonic sound sytem
The wireless speakers for my Panasonic sc-pt956 sound system wont work. the wireless receiver is on and has a green light on it, so i don't know what the problem is.
  • 1 more comment
  • strobman Dec 26, 2008
    they are about 4-5 meters away from the transmitter and there is nothing in the way. i tried bringing them closer to the transmitter, but it didn't work. could the problem be the strange way that the transmitter pugs into the main unit? it has a screw like thing that the manual says to put the wire into the screw. it didn't really make sense to me.
  • Anonymous May 01, 2009
    I have the exact same problem with the SC-PT660.  Green light is on in remote box and speakers work fine when hard wired to another receiver.  When set up according to instructions, I receive an error message on the main module.
    Have tried to call Panasonic support to no avail.
    Did you ever resolve this problem.
  • Joesipaq May 11, 2010
    How far away are the wireless speakers away from the transmitter, are there any obstructions in the way? Will the speakers work at a closer distance?
Try looking at the training document for your system. The answer might be there.
Posted on Jan 25, 2009
Hi, Can I buy a 5 disc changer for the panasonic SA-PT956 home theatre system, sounds like it has stripped gears. Thanks
They are available from panasonic. I have replaced many. There is a skill level needed to work on one of these. You should get the service manual also.
Sep 01, 2011 | Panasonic Audio Players & Recorders
My Panasonic SC-HT995W keeps on flashing W and the rear speakers wont work. Ive tried turning off all other wireless devices but it still persists
I had exactly the same problem. My unit worked fine until a loose power cable resulted in the receiver being turned on and off a couple of times in quick succession and then after this the a/c in light on the rear speaker was lit but the wireless link light would not come on (and the 'W' on the main unit flashed constantly). The solution for me was basically a reboot. This is what I did;
- unplug the wireless receiver
- unplug the main unit
- remove the digital transceiver unit from its slot in the back of the main unit
- plug the main unit back in and turn it on - the 'W' won't flash as the transceiver has been removed (not sure if you if it's necessary but I made sure it was producing sound to the front speakers)
- unplug the main unit again
- reinsert the digital transceiver
- plug the main unit back in, turn it on and set it to produce output/sound (the 'W' will be flashing)
- then plug the wireless receiver back in again
...presto the link is made, the 'W' stops flashing and the rear speakers work again.
Hope this elaborate reboot works as well for you as it did for me.
Aug 08, 2010 | Panasonic SC-HT995W System
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Wireless digital transmitter doesn't work
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Oct 06, 2009 | Panasonic Audio Players & Recorders
Product did not come with any instructions etc
Try  here is the address for your manual:
Jan 07, 2009 | Panasonic SC-PT960 Theater System with...
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Wireless speakers
You should have two pieces for your wireless rear speakers setup. A. a wireless card inserted behind the all in one receiver. B. the receiving box that will connect to the 2 rear speakers.Also,you should not have any obstacles to block off the line of site for the rear speaker receiving box to the wireless card.
Best way to test it is too simply leave the rear speakers connected to the rear speakers receiving box on the floor near the a/v receiver with dvd player built in.Play a dvd and see if you have sound coming out from the rear.
Nov 01, 2008 | Panasonic Home Theater System System
Hi...I found your post while searching for the answer to the same question!  I thought I'd let you know what the tech support person told me, which worked immediately.  There is a button on your remote that says MUSIC with SRD above it.  Push this button, while surround sound speakers are on, and they should work instantly.  They are quieter than the regular speakers, so you might have to turn up the sound.  Hope this works for you (if you are still having troubles, that is).  The manual was no help with this subject.  So frustrating!
Jun 30, 2008 | Panasonic Home Theater System System
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
776 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
