Question about Beko 324250WN 28" TV
BEKO TRW325 TV. Frozen on chanel 1.
I was making adjustments to the chanel set up and the TV has become frozen on chanel 1. The chanel works perfectly but I am unable to change chanels from the remote control or manually. The remote contol is ineffectual - I'm unable to get the menu displayed to readjust the chanel set up. Please help if you have any ideas?
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Posted on Dec 27, 2008
I have a beko frost free fridge freezer its only 18 months old and Ive got a build up of ice in the fridge. all my food is getting frozen and Ive got my temp dial down to min .cant understand what cou
Is the door seal working correctly? If the door has become distorted slightly it might be letting in moisture via a gap in the door seal which will result in the build up in ice.
If you can see ice build up leading from the door area, this will give you a clue to where the seal may be faulty. Check that the door is squared up to the freezer with a spirit level and if required gently bend the door back into place by holding the corner with your feet and adjust from the other corner.
Oct 07, 2014 | Beko CDA670FS 280 litre Frost Free Fridge...
I have a beko upright freezer but it has a funny smell in it and it dont keep the food frozen why
maybe you should put a box of Arm&Hammer Baking Soda in it, then plug it in.
Aug 21, 2012 | Beko TLDA662
HP Pavillion Laptop 1/3 Bottom Screen intermittently inaccessible
Sub out the ram memory one at a time and to see if this will make the difference.
Apr 22, 2012 | HP Computers & Internet
Is it worth getting my fridge freezer fixed?
Check out the start cap/relay on compressor.
Apr 10, 2017 | Refrigerators
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Blackberry is frozen and will not reboot with either alt+caps+del or battery pull
1-Give the Blackberry at least 1 minute without pressing any buttons or selecting any applications. Give it a chance to catch up and make sure it's actually "frozen".
2-Give the Blackberry at least 1 minute without pressing any buttons or selecting any applications. Give it a chance to catch up and make sure it's actually "frozen".
3-If the Blackberry is not "soft frozen" then it is in fact "hard frozen", which is generally where your smart phone will remain until you reboot it. To reboot open the battery door on the back of the Blackberry and simply remove the battery completely. Allow the Blackberry to sit without a battery inserted for at least 30 seconds.
4-Put the battery back into the Blackberry smart phone. It will take anywhere from 1 to 5 minutes to completely power up and become ready for use again. Your frozen Blackberry problems are now solved!
Apr 16, 2011 | Cell Phones
Liquids frozen in refrigerator, no water from water dispenser
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
My tv screen is frozen. I can change channels but the screen stays frozen
unplug the TV wait 1 hour plug back in and see what happens set should return to normal.
Jun 08, 2008 | Televison & Video
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Beko 324250WN 28" TV Logo
303 people viewed this question
Top Beko Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
