Question about Car Audio & Video
No memery on aftermarket radio
Its a 94 murcry couger
  • 44 Answers
The AC which is most likely the red wire on the receiver and the constant (yellow) must be together ... constant is what keeps the memory.. cross the red and yellow (make sure it is the constant before you cross) to the AC coming from the wiring harness.
Posted on Dec 26, 2008
How do I wire after market stereo to 94 ford probe
check the radio stores as you may be able to get a radio harness to connect the aftermarket radio to the factory wiring harness so you won`t have to cut and splice, its just a plug and go.
Oct 13, 2014 | 1994 Ford Probe
What is the firing order for the wires for a 94 mercury couger 4.6 liter ohc sep coil packs
1994 Mercury Cougar/XR7 4.6 liter SOHC V-8 VIN "W"
Hope helps (remember rated and comment this).
Sep 01, 2010 | 1994 Mercury Cougar
I own a 99 couger and my radio wont work,if checked the fuse and its fine. the radio just wont turn on at all
now it really matters on what kind of radio it is but most have a built in fuse try lookin in to if yours does also check the hot wire and the negative wire leading into your radio this should work :)
Mar 24, 2010 | 1999 Mercury Cougar
My radio on my 94 chevy pickup will not go on it stays on 1:00 or 98.3 no sound is it locked?
unless you have a aftermarket stereo chances are it does not have a lockout installed. Sounds more like a faulty circuit in the radio wiring. Check all connections to eliminate loose or burnt wiring . Depending on how hard the truck has been driven it may just have worn out it's day from vibrations.
Mar 20, 2010 | Car Audio & Video
Putting cd player in 94 explorer?? HELP PLEASE?!?!?!?
Yes, that would be fine, make sure you solder the wires and tape well or use shrink tube on the connections.
Mar 13, 2010 | 1994 Ford Explorer Limited
I need a code for a Becker Radio of my mercedes c220 94' with the following details: Model No BE 1492 Serial No. r1038146
You have to get it from the Dealers service dept. They call in the vehicle ID and Serial # of the radio to get the code, and they all charge for the service. Factory radio or aftermarket radio. Hope this helps
Dec 22, 2009 | Electronics - Others
My 92 mercury couger brake line is leaking,how do i replace?
my 94 cougar needs brake springs i need to know where they go
Jul 13, 2009 | Mercury Cougar Cars & Trucks
Wireing problem with aftermarket stereo
you are going to need a test light.there are 2 power wires one of the wires will only have power when the key is on.the other wire will have power all the time for the memery backup/clock if i remember correctly you are looking for a orange wire and a red wire and i think its the orange wire for the memery backup. p.s check the fuses your truck has two for the radio.
Mar 16, 2009 | Pioneer DEH-P4100
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Como poner un estereo
estereo original? o uno comprado aftermarket? eso significa un radio o estereo no origina
Jun 28, 2008 | 1994 Toyota 4Runner
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
