Question about Toshiba 26AV500U 26 in. LCD HDTV
Programming remote I cannot get from Direct TV or any internet forums a programming code to enable me to program a RC64 remote that came with a H21-100 receiver to control a Toshiba 26AV52U HDTV. Bandster
  • bandster Dec 26, 2008
    Tried all codes suggested by classyexpert and none work!
  • 916 Answers
Move slider to TV
pres mute + select until you get a double blink
press 991
then 1
press power on
press channel up until TV reacts
then press select and you will get a double blink
Posted on Dec 26, 2008
  • 100 Answers
I have included all the codes and the procedure for the RC64. You may have these already or you could be making a mistake when programming the remote. Good Luck
codes:---10154, 10236, 10463, 10180,10178, 10171, 11963, 11944,11929, 11928, 11911, 11394,10623, 10282, 10280, 10270,10185, 10183, 10182, 10181,10179, 10177, 10158, 10039,10038, 10019
Power on the DIRECTV Receiver.
Slide the MODE switch to the DIRECTV position.
Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
DIRECTV position flashes twice.
Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps , trying each
code for your brand until you find the correct code.
____________________________________
For Directv remotes try Toshiba codes. use Toshiba code 10156 on model RC23 Directv remote and it should work
1. Switch the selector to TV on the top of the remote.
2. Press both the Mute & Select buttons at the same time until the green light blinks twice.
3. Enter code.
4. Press Power button.
Make sure you are in front of your television about 3 feet away. The remote signal doesn't seem to work well even at a slight angle.
P.S. If that codes doesn't work here are the other Toshiba codes listed on Directv.com for the RC23 Remote.
11656 11256 11704 11356 10650
10060 10154
  • 10,594 Answers
Following codes are for Toshiba TV...
10154, 11256, 10156, 10093,
11265, 10060, 11356, 11369,
11524, 11635, 11656, 11704,
11918, 11935, 11936, 11945,
12006, 11343, 11325, 11306,
11164, 11156, 10845, 10832,
10822, 10650, 10149, 10036,
10070
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If code is not available, perhaps you could try manual code search (but might take some time). As explained in the manual, pls try:
  1. Power on the TV on a cable channel;
  2. slide MODE switch to TV;
  3. press and hold the MUTE and SELECT keys simultaneously until green light flashes twice;
  4. release both keys;
  5. enter 9 - 9 - 1 followed by 1 (for TV);
  6. press PWR;
  7. point remote at Toshiba;
  8. press CHAN up repeatedly until Toshiba TV powers off
  9. use CHAN down to backdown a step/code;
  10. press and release SLECT key.
  • Note: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Good luck and Thank you for using FixYa. Happy Holidays.
    Sergeant:
    Novelist:
  • 327 Answers
Http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC64forWeb.pdf just click this link and get the instructions to programm the remote.
Direct tv remote rc64 how to program sdtv magnovox box
In order to program a Directv remote you slide the switch at the top to tv, hold down the mute and select button at the same time until the indicator light at the top of the remote flashes twice. Then you enter a 5 digit code. If you go to the directv website http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380036#h:620.315
and put in the brand and model of your tv, it should show you what code to use.
Oct 11, 2014 | Universal Remote Control DIRECTV Universal...
I need the code to program sony ble-ray dvd player, BDP-S300, into my RC64 Direct TV universal remote
If the remote is more than ~ 2 years old, it probably won't have a code set for your Sony. Check the DTV site for latest code info.
Feb 18, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I have the Direct TV RC64 remote and the Sylvania TV/DVD Combo Model LD320SSX. Is there any way I can program this to control the volume and power for the TV?
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Nov 28, 2009 | Sylvania LD320SSX LCD TV
Need remote code
Humax codes are,1325,1565,1569 Ted10
Apr 16, 2009 | Humax LD2060 20 in. EDTV-Ready LCD...
Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
Jan 17, 2009 | Universal Remote Control DIRECTV Universal...
Need code to program toshiba tv with Direct tv remote
I HAVE A TOSHIBA 32A33 TV AND JUST UPGRADED MY RECEIVERS AND REMOTES I CANNOT GET THE DIRECT TV UNIVERSAL REMOTE RC64 CODES THAT THEY HAVE PROVIDED TO WORK, ANY ADDITIONAL CODES ? PLEASE HELP
Dec 06, 2008 | Directv RC23 Remote Control
Can't find the remote control codes
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series. ALSO try code 10835.
Sep 06, 2008 | Televison & Video
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
Toshiba 26AV500U 26 in. LCD HDTV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
