Question about Raymarine SeaTalk hs, 20m (E55052)
Fishfinder problems I have a Koden cvs-821 model fishfinder. It has started losing signal. Everytime we initially turn it on it works fine and gathers the signal. After a while, and usually when we are at sea, it appears to get depth confusion, puts up a question mark ?, and the screen stops movement. Any signal then disappears and the screen goes to its normal background blue. The sounder then is not able to recover the signal. Oddly enough whenever it has been off for any length of time, which is usually after we are home or the next day, it works fine again. We took it to a technician and he couldnt find anything wrong with it as it worked fine. Could it be a faulty transducer or it it likely to be in the in the sounder.
  • 16 Answers
SOURCE: Raymarine C120
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
SOURCE: Raymarine L365 Fishfinder not registering data, it just flashes
Got a brand new one in box - let me know if interested..
mriley20@comcast.net
Posted on May 28, 2010
  • 3 Answers
SOURCE: MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Posted on Jan 25, 2011
snowghost1
  • 784 Answers
SOURCE: Hello, our Raymarine ST40 depth sounder on our
now there is a chance that the transducer is bad ,, but I would check the battery voltage and make sure you have a soild 12 volts to the unit. also in my many years of working with and installing these units on boats I have see the needle pins ( where the plug inserts in the back of the display unit ) bend and/or break off completely. look in the plug area of the display unit and make sure all pins are intact. one more place to look for the problem is in the plug itself, take the plug apart and inspect the wire connection and make sure they are all good. if after all the above has been checked then I would assume that it is the transducer itself.
if you have anymore questions with this problem, please feel free to write back and ask,
c...
Posted on Jan 30, 2011
SOURCE: manuel for koden cvs-801
Contact the manufacturer and order the manual.
Posted on Apr 24, 2012
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
Jun 07, 2016 | Garmin Color Fishfinder 160c
The unit loses the signal at higher speeds
The signal loss is due to the transducer not in the water. Suggest remounting the Xducer an inch or 2 lower to be in water when you plane out at full throttle.
Sep 04, 2013 | Humminbird 561 Fishfinder
Gps wont work but fishfinder works fine
This model has two versions, one with the GPS as an external piece, and one with the GPS mounted internally. If the location of the internal mounted GPS cannot get a clear shot at the satellites overhead, it will tell you it cannot get a GPS fix. If it says it is disconnected, you may have a problem with the internal GPS. There are external GPS pucks available for this unit. Here is a helpful website.
http://www.humminbird.com/leading_innovation/fishing-systems.aspx
Nov 07, 2011 | Humminbird 788ci Color Fishfinder Combo...
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Jul 27, 2010 | Raymarine A65 Combo GPS...
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
Lowrance x96 does not function after 20 feet depth
Your transducer needs to be adjusted so the return signal can be picked up. Some of these have to be super tuned to receive the signal. Also the transducer may be moving ever so slightly when the boat is traveling at speed. You may have some water turbulence interference all contibute to signal return.
May 26, 2009 | Lowrance X96 200khz Fishfinder
Fishfinder 300C has stopped working, despite being only 3 months
I checked the fuse and it looked OK, however working on a hunch I decided to replace the fuse anyway. This immediately addressed the problem and my Fishfinder is now working again.
Dec 31, 2008 | Garmin Computers & Internet
Humminbird fishfinder keeps blowing 5v fuses .Power ok to base but as soon as you attach fishfinder fuse blows
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Humminbird GPS
Apelco 365 fishfinder. Broken pin on power connector
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Raymarine SeaTalk hs, 20m (E55052) Logo
126 people viewed this question
Top Raymarine Computers & Internet Experts
David Payne
David Payne
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
