Question about Delphi SKYFi2 SA10101 XM Radio Receiver
No signal: delphi sa10101 and delphi sa10201
Just got both of these. The receiver is suppose to hook into the delphi boombox. Everything, including the antenna is hooked in nice and tight. I activated the service, waited an hour or so, and still when I try to go to any channels I get the message "antenna". I tried the "Antenna Aiming" option but I get no signal at all. Terrestrial and satellite do not work. I'm thinking it's the antenna or the boombox, but I'm not sure. Everything is hooked in correctly. Any ideas??
SOURCE: Cannot Get Antenna To Pick-Up Signal
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Posted on Jan 05, 2007
  • 13 Answers
SOURCE: Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Posted on Sep 28, 2008
how do i connect my xm roady sa10035 to my car cd player?
Posted on Feb 02, 2009
Bubbabear64
  • 2794 Answers
SOURCE: scroll wheel
Try TSS-Radio.com.
Posted on Apr 08, 2009
SOURCE: xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Posted on Jun 04, 2009
No singal antenna on delphi sa10175
Could be the antenna, the dock, or the radio itself. If you have another kit or boombox, I would try swapping antennas out and so forth to narrow down which part is causing the issue. www.tss-radio.com has replacement parts.
Jun 03, 2012 | Delphi Roady XT XM Radio Receiver
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
XM Receiver: When hooked up to the home kit it will show antenna and will not pick up a signal. When hooked into the car jack it works ok. I replaced the receiver mount about 3 weeks ago and it worked ok...
Hi Kldeaton,
If you can do it, try your car mount in the house, as long as you can supply power via the car plug (12-volts DC). If it does the same thing as the home kit, then you more than likely have an intermittent antenna connection on your home antenna.
Also, check the location of your antenna vs any obstructions, such as trees. You may have the reception worked out so that you have signal from the antenna, but it is "breaking up" from a connector or cable short or open condition. Check the coax for any chaffing also. Let me know if you need more help. Thanks.
Regards, Bill
Sep 28, 2010 | Delphi Roady XT XM Radio Receiver
No sound from boombox
hook it up to a sound box
Sep 01, 2010 | Delphi SA10201 Boombox
I need a replacement antenna for a Delphi boombox.
Try radio shack. #270-1401, #270-1405
http://www.radioshack.com/family/index.jsp?categoryId=2032206&cp=2032057.2032187.2032189
Mar 15, 2010 | RCA RCD152 Boombox
Delphi Shyfi XM radio only picks up certain channels in the car cradle but picks up all of them on the Boombox. Why?
XM actually uses 2 sets of transmitters on each satellite, so it is possible you need to adjust your antenna to get the rest of the channels in the car cradle.
Sep 30, 2009 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Antenna message on roady display
I have the same problem. I hooked it up to a different antenna and it works
Nov 04, 2008 | Delphi Roady XT XM Radio Receiver
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
Delphi SKYFi2 SA10101 XM Radio Receiver Logo
150 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
