Question about Archos 604 WiFi Digital Media Player
Archos want work
Any time i turn my archos on i get the archos screen and i hear like 3 or 4 clicks and it would just stay at the archos screen
    Problem Solver:
  • 6 Answers
Sounds like a disk problem. This might work for you ...
Power off the unit
[Optional step - remove battery and use a pen to push the reset button]
HOLD down the LOCK/TV-LCD button as you press the POWER button until the unit starts to come on.
You should should get options to recover the disk (try this first) or format the unit (try this last).
If that doesn't work i would follow the procedure of reseating the HDD connection - see solution for Recovery error code 2 problem.
Posted on Jan 10, 2009
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
I have an archos 5 and and it stay on the begging screen
try hitting the reset button as a first step when it comes on. You might have to do a hard reset. Make sure you have either your original firmware or the latest from Archos saved on your desktop. When you do a hard reset if it comes to the Archos screen hold down the volume+ button until the white recovery screen comes on. If you have data you don't want to lose in it you might be able to save it if you try the repair or recovery function but if they don't work you will lose everything if you have to format. You probably will have to format sorry for the bad news but try everything first before formatting.
Aug 01, 2009 | Archos 5 MP3 Player
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
Not turning on
This may work but it may not my Archos use to do something like that too. What you do is when it comes on press the on but again but not hard or long enough for it to shut down and tap the screen do this reaptedly untill you see the red light start to flas reaptedly really quickly without stop then it will stop and flash two or three more times untill you see your screen come up oh nd next time dont full shutdown just suspend it it is easier and it doesnt take up battery life either.
Feb 12, 2009 | Archos 605 WiFi Digital Media Player
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
197 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
