Question about IBM NetVista PC Desktop
Maximum harddrive size for netvista pc
I want to replace my 40 GB HDD with a bigger HDD. How can I find out what max. capacity of HDD can I put on my NetVista 6793-22A PC? You Guru's please help with this one?
I've searched the net but hasn't been successful in finding any info.
Thanks.
CosyGlow
    Scholar:
  • 100 Answers
Well i think you could get away with 120 gigs. if you go over that you should update your bios and run a utility like Big Drive Enable--
http://www.seagate.com/staticfiles/maxtor/en_us/downloads/big_drive_enabler.exe
there are others out there though.
Posted on Dec 26, 2008
What is the max size of harddrive that can be installed on a aspire 5515
you can easily replace with 500gb hdd
i can see no problem with putting even bigger hdd into your laptop
Oct 08, 2010 | Aspire Acer 7520-5071 Notebook
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
What is the maximum addressable disk size for a Dell Dimension 2350? I currently have a 120 gb drive partitioned in thirds (40 gb each) that I would like to change to 2 * 60 gb.
depending on what space you have free is your max, you can use any size you like but again it depends on what is your maximun disk size. hope this helps in some way.. for the size you have now 120 gb, u need at least 10 gigs for windows and programmes to install. so 110 is your max you can play with i think.
Dec 03, 2009 | Dell Dimension 2350 PC Desktop
What is the max HDD size for my Acer T135. Can I
yep - there is no maximum HDD size for computers just as long as you have the right connection (Sata or IDE) then you can fit any size you like.
Enjoy :D
Dec 03, 2009 | Acer Aspire T135 PC Desktop
HDD capacity greater than 128GB with Acer Travelmate 2300
ive had a look on the acer website and there is a replacement bios available , but theres no mention if it would enable large Hd support , rather than flashing your bios and potentially destroying your laptop i would purchase a external drive , you can get the enclosures for 10-20 pounds and fit a decent size HD in this
http://www.ebuyer.com/product/159438/show_product_reviews
Nov 09, 2009 | Acer TravelMate 2300 Notebook
Bigger hdd for sony vaio pcg-f309
You can use 20/40 Gb hard drives. the BIOS may be too old to support the 60/80Gb hard drive.
The only problem is, that it is impossible to purchase new hard drives of these capacities, the smallest capacity available now are 120Gb and larger.
You may be able to get 2nd hand drivers, but you won't not know how long they will work until they fail, probably doesn't matter, they should be cheap.
Apr 12, 2009 | Sony Computers & Internet
Ram upgrade
In most cases if you put of not thesame capacity in any computer later will create further problems. it can damage the other memory or both and the worse is when also the motherboard will also damage.
That is why im telling you this. Please prevent inserting memory of two or three different capacity. You should not do that.
You should select etheir use all 256mb or all 512mb or all 1gb.
in the T4200 since max. is 1.5gb, either use 3-512mb if can carry the maximum if not , then use only 2-512mb.
in T3624 since max is 2GB. You can try 2-1gb if can carry the maximum if not, use only 1-1gb.
Note:
You can use or inserting at different capacity but is at your own risk. "
Ps. does no matter either you put smaller or bigger in first slot.
Mar 18, 2008 | E-Machines eMachines Desktop PC
Want To Replacing My Toshiba A10-S330 Hard Disk
Normally you can upgrade to a new hard disk to the next bigger size, so from 40 Gb, then perhaps a 60 or even an 80 would work. Even if the BIOS/motherboard would not recognized the new size, Windows XP would and be able to access it.
However, I don't think that the size should really be the main concern. I think that your selection should be based primarily on the power consumption. Most laptops have a preset power distributed to its devices. If you are going to use a bigger size HD with a bigger power consumption, Windows (or even your BIOS) might recognize it but the power distribution might be over worked.
My suggestion would then be go to the next size but keep in mind the power rating/consumption of the old when selecting.
I am enclosing an image of my laptop's HD. Pls note the rating DC+5V 0.7A for this 60Gb HD. The 0.7A is its current consumption/rating.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 12, 2007 | Toshiba Satellite A10 Notebook
IBM NetVista PC Desktop Logo
46 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
