Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
Looking for relacement engine-running
Mod- M16S
Spec- 711521
Current engine taken to small engine repair facility for F & R seal and oil pan gasket replacement
Posted on Dec 27, 2008
I need valve spec,s for mod PM0435001,
For specs on the engine, look for engine model number and type then google. You will find the engine model number either on the block of the engine or on the fan cover. If you can't find a number, google the brand of the engine using search key " engine model number location" ex Briggs model number location. Could be either briggs, tech, honda or other. Good luck.
May 22, 2013 | Coleman Powermate Electric Generator...
1994 corolla dx 1.8L running rich problems
with the money u hav left look into the injector drive circuit of the computer-thatz wat runs rich and leen--may need a new one or hav whole computer reprogramed-easier
Jan 23, 2013 | 1994 Toyota Corolla
Where can i buy , head gasket wagon r/k10A-M16S engine type
immediatly after starting or after a while n where u from
Oct 23, 2012 | Cars & Trucks
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
Engine turns over but won't fire up. Relaced plugs, plug wire, dist cap and rotor. Still nothing. What should I look for next?
you're changing parts for nothing here, you need a spark tester(in line works best) injector signal tester(noid light) fuel pressure guage, and in a pinch compression guage, spark, fuel, compression, no engine will run without all three
May 29, 2010 | 1995 Nissan Altima
Noise from the engine when coasting sounds a little like noisy lifters in a car ,only happens after the engine has been running a while
how long has it been since your last service if your doing them yourself its wise to keep a record to long between oil changes reduces the viscosity of the oil this can contribute to noisy tappets thin or burnt oil does little more than keep the engine wet you say the noise only occures after the engine has been running a while this would indicate that as its warming up the oil is thining & in effect not provideing optimum lubrication also you should check your valve clearances & if ther found to be out of spec adjust them accordingly I dont do that many yamys so Im not sure wether your's is shims or adjusters being a later mod Im inclined to think its shims
Feb 25, 2010 | 1999 Yamaha YZF-R6
I prime it it runs for about 1.5-2 sec. then stops.
Assuming you have a Tecumseh engine, replace the primer bulb. Make sure you get the correct one, there are 5 different ones that will fit. when you get it from your dealer make sure you have engine mod. & spec. #
Also make sure the dealer gives you the correct one, not just one that will "fit"
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
I am trying to get amanual for a troy bilt tiller s/n 7492483 mod#k161t spec#281181j
troy bilt says that there is no such model number.if you would check it again and i'll look for one for you. or you can go to http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_TroyBilt_10101_19502_-1 and look for yor self.
Mar 09, 2009 | Garden
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
163 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
