Question about Dell E173FP 17" LCD Monitor
Dead, Dell E176FPf
Set is dead,no dc output could be mesured, only about 2volts or so, and no seemingly s/c could be traced.
    Problem Solver:
  • 19 Answers
If it is still inside the three year monitor warranty period I would recommend calling tech support to have it replaced. Larry Dell Customer Advocate
Posted on Apr 23, 2007
Lenovo g560 comes on but no display tried connecting to monitor still same
did you use the external VGA port and then not use the lenovo
hot key to turn that on Fn?
remove the huge battery first and run on AC pack now? only?
screen dead no text? this is bios, must never be dead.
no lenovo, icon, at power on this is bios.
fan dead silent.?
is the HDD (ear to casing) dead silent , prooving dead HDD.
run HDD tests? if heard to spin
if all above is dead that means power is gone.
try new AC pack for $8 cost?
or use voltmeter on yours see if it is dead? pack output pins DC.
Oct 13, 2018 | Lenovo Computers & Internet
DEAD AC ADAPTER OUTPUT DC VOLTAGE IS ZERO
Check fuse in plug. If that's OK buy a replacement adapter. Cheap on eBay!
Jan 03, 2014 | Computers & Internet
When connected to AC mains and switched on there was no sign of glowing led displaying charger is "ON"
Use multimeter to check output of AC Adapter. If no DC output at required voltage you should replace adapter; available after market units sell for $10 to $15 delivered.
Jan 03, 2014 | Compaq 239427-001 Laptop AC Adapter...
Someone gave me used Zenith HDTV. Everyone is yellow, grass is yellow, etc. Can't seem to fix it.
Hi
It seems your TV set has a problem in the R ( red) gun in the RGB circuit. It means that the red color circuit is missing. To fix this fault it requires some knowledge in electronics and is a good challenge for an electronics hobbist. Generally is a faulty RGB output transistor on the small board attached to the CRT neck. To trace it, mesure the voltages in the colector of the three big transistors on the mentioned board. One of them may have low voltage or even none. That is the culprit. Replace it and you are done.
Good luck.
Sully
Sep 21, 2013 | Zenith Televison & Video
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
Technics SU-G75, No Speaker Output, Headphones Work. So I woke up this morning to find that my roof leaked ...onto my laptop and stereo. I love this amp, bought it new with all accessories in 1993,...
The fact you have output from the headphones is a good sign. It shows the main amp is working fine. However water has clearly got inside something and affected it. The best course of action is to trace back the wires from the headphone socket and see if there is a relay or anything that could get water in it. If you do find something, try applying warm air from a hairdryer. The alternative is to apply a soldering iron to the solder conections of the device. This should get rid of any water inside. If all else fails you might have to replace the relay. But I would try a spray of Servisol first. Just in case some dust has got inside or mineral salt from the water.
Nov 09, 2011 | Technics SUV500 2-Channel Amplifier
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
Dell latitude d500 had a power socket problem, but now resolved pc will not boot-up, drive spins-up, then nothing, completely dead display i think most likely scenario is mobo is fried, but open to...
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Oct 10, 2009 | Dell Latitude D500 Notebook
Inspiron 1521 adapter vs battery
take an ohm meter you can buy for ten bucks at radio shack put the volt meter on DC volts plug the charger into the battery charger end the black lead goes tothe outside and the red goes inside, set the meter for 12 volts dv and mesure the voltage. read the voltage output on the battery charger transformer see if it's within a half volt if not the charger is bad, if it's ok then use rubbing achol and a q tip to clean the battery connectors on the computer and the battery itself, if you do not get the light then pull the battery out and hold the power button in the on postion and hold the enter key for 1 minute and try again, if the lights do not come back on your battery is dead, if the computer will still boot with the battery then the charger is working if it won't boot up the battery is dead. Got it?
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Dell E173FP 17" LCD Monitor Logo
503 people viewed this question
Clive
Clive
Alun Cox
