Question about Pacific Image PrimeFilm 1800 Film Scanner
PF 1800 Scanner Silver--not scanning porperly
I have had this scanner for a few years--it was working fine when I used it about 2 weeks ago. Today it pre scans/scans a slide--the mechanism is moving over the slide--but the resulting image in a completely white box. I reset all of the settings and then I dumped and reloaded the software but that didn't solve the problem. When I look inside I can see the low purple light  so I think the bulb is still working.
Any suggestions? Thanks Loren
  • loren76 Dec 26, 2008
    I took the lid off the scanner and blew it off with air. Then I put it back together and ran it--with the front portion of the cover up. I could see that the front lid was moving over the slide but the resulting image  blank.
  • 100 Answers
The scanner assembly is getting blocked somewhere internally due to dust collected in the assebly.or it can be due to any of the wire internally gone loose or cut slightly so this problem.
Posted on Dec 25, 2008
Epson v300
Make sure you have Adobe acrobat or similar installed so that you have PDF available on the PC. It may also be in the software for the Epson. I had a scanner a few years ago whose software excluded PDF and I ended up installing new software of a generic printer / scanner to use Adobe PDF
Jun 07, 2012 | Epson Perfection V300 Film Flatbed Scanner
Scanning Blank
Try and re-install the scanner, check the settings of the scanner software you are using and change the settings to scan picture or scan in colour. Thanks
May 13, 2010 | IRIScan Executive 2 Flatbed Scanner
Push button to operate and nothing happens
Scan via Twain plugin (photoshop) for the N 650U is the only solution working for me. Front button stopped working after a needed update 3 or so years ago, don't expect that to work anymore.
I am using Mac OS X Snow Leopard on an Intel MPB.
- - cognitdiss
Feb 15, 2010 | Canon CanoScan N650U Flatbed Scanner
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
Acer scanner Prisa 620PT won't work with Windows XP
I can only speak from experience but I have found HP to be one of the best for what you need.
Example here
http://h10010.www1.hp.com/wwpc/uk/en/sm/WF05a/15179-15179-64195-3445112-3445112-3423844.html
Aug 06, 2009 | AcerScan 620ST Flatbed Scanner
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
My hp c1300 all in one is not scanning!!!
Try this, unplug it from wall. Wait 5 minutes, plug it in & try again. You may have to reinstall the software since it's been awhile. Sometimes the updates that "good old gates" sends us messes with our hardware drivers ect.
Feb 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Epson V700 Photo Scanner
are you scanning it at the right resolution and are you using the negative holder?
Nov 09, 2007 | Office Equipment & Supplies
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Pacific Image PrimeFilm 1800 Film Scanner Logo
293 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
