Slide out will not slide out
I have a 26 foot travel trailer, Prowler b y Fleetwood and the slide out will not move out.  The motor only clicks but if I select in the motor runs and the unit bumps as it does when it all the way in.  Do I need a new motor or is there some other problem?
Thanks,
Thanks, I fixed the problem so pleasse take me off your email list
Posted on Dec 26, 2008
I have a 2004 Fleetwood prowler lynx travel trailer with an electric slideout. When I press the button for it to slide out it won't do anything but if I press the button to come in it will come in
Maybe it has a bow in where it extends or unlevel spot I'm just guessing or something caught in it. I would see if someone could be outside gently pulling as someone held the button for it to extend. or check to see if it needs lube
Aug 26, 2017 | Cars & Trucks
WIRING MANUAL FOR 1990 FLEETWOOD PROWLER TRAVEL TRAILER
well I do believe the possibility of you finding a manual for 26 year old trailer are not too good , but try this diagram its helped me out on some old ones before
https://www.etrailer.com/faq-wiring.aspx
Aug 09, 2016 | Cars & Trucks
1991 Fleetwood Prowler travel trailer when I hook up to it the first half of my trailer clearance lights are working the back half nothing's working
The clearance lights are most likely in an series circuit in this case. They will go down the right side as you are looking at it from the front. The last light that is lit is where you will look for connection problems If this is set up as a series parallel then your first light on the left side is the place to start looking for a bad connection.
Apr 30, 2016 | Cars & Trucks
Manual for 2006 FLEETWOOD prowler camper
Even though Fleetwood no longer manufactures Travel Trailers you may still want to call Fleetwood RV Owner Relations at 1-800-322-8216 and see if they can help you out with locating a manual.
You could also try ebay and see if anyone is selling a manual.
You could try facebook for an rv community.
or try this link
http://www.rvingthemidwestconnection.com/manuals1990newer.htm
Oct 23, 2015 | Cars & Trucks
I need a main breaker what size is it for a 1994guy Fleetwood prowler travel trailer
you take the old one out and with you to any place that sells breakers , they will match the new one up for you .
Sep 29, 2015 | Cars & Trucks
Were can I get a owners Manuel for a 1994 prowler 24ft. Travel trailer?
That's a tough one! I've tried for nearly a year now to find a manual for a 1988 Fleetwood Wilderness Yukon. I was finally able to find one on eBay but the manual I found is NOT for my exact trailer (it's for a larger model).
Best resource, if you have no luck through the manufacturer, is to continue checking eBay. Otherwise, if you have already conducted searches using GOOGLE and YAHOO, you're looking for a needle in a haystack.
May 16, 2015 | Cars & Trucks
Slide out will not slide it is out but will not slide in, Battery is fully charge & electric is on. Any suggestions? 1998 Fleetwood Mallard 26' travel trailer
GO TO THE ELECTRICAL PANEL WHERE THE CIRCUIT BREAKERS ARE,ON MOST MODELS, THE DC INVERTER (12VOLT) IS BUILT TO THE AC (120 VOLT)BREAKER BOX.CHECK THE FUSES ON THE DC INVERTER SIDE(SHOULD LOOK LIKE AUTOMOTIVE FUSES) IF FUSES ARE GOOD,CHECK FOR PROBLEMS AT THE TRAVEL LIMIT SWITCH LOCATED SOMEWHERE AROUND THE TRACKS THAT THE SLIDE TRAVELS ON.SOMETIMES AFTER SITTING FOR A WHILE THE LIMIT SWITCH DO NOT MAKE PROPER CONTACT FROM AGE,USAGE, CORROSION,ECT.,EASY THING TO TRY IS MANUALLY MOVE THE ACTUATOR ON THE LIMIT SWITCH SEVERAL TIMES WITH YOUR HAND ,YOU SHOULD FEEL OR HEAR IT CLICK. THOUGH IT IS SELDOM THAT THE LIMIT SWITCH IS A PROBLEM,IF THE FUSES ARE ALL GOOD,THE ONLY THING LEFT IS THE SLIDE MOTOR WHICH CAN BE LOCATED UNDER THE TRAILER AROUND THE SLIDE TRACKS,UNPLUG THE WIRES,HAVE SOMEONE PUSH THE SWITCH WHILE SOMEONE CHECKS FOR VOLTAGE AT THE MOTOR,YOU SHOULD USE A TEST METER ABLE TO READ AND VERIFY 12 VOLTS DC.IF YOU HAVE 12 VOLTS DC WHEN BUTTON IS PUSHED,MOTOR MAY BE BAD,PLUG WIRES BACK TOGETHER,MOVE TO A SAFE PLACE AWAY FROM POTENTIAL PINCH POINTS AND PUSH THE BUTTON AGAIN.
THERE MAY BE A CHANCE OF BAD CONNECTION AT THE MOTOR PLUG.
I HOPE THIS IS NOT TOO CONFUSING,AND THE PROBLEM IS ONLY A FUSE BECAUSE A FUSE IS A MUCH SIMPLER,CHEAPER FIX.
BEST OF LUCK.
Oct 30, 2010 | Electronics - Others
Computers & Internet Logo
446 people viewed this question
David Payne
David Payne
