Question about Freecom (24358) 160 GB Network Hard Drive
Freecom external hard drive classic 2.5
My computer crashed about month ago had re boot now have tried put external drive back on wont load can help cheers
  • 6,831 Answers
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Posted on Sep 29, 2010
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Hi i have just tryed to connect my FREECOM 160GB EXTERNAL HARD DRIVE to my imac and nothing happens at all, the light on the front of the hard drive is on but it does not show on the imac desktop, i went...
you have to download the driver for the hard drive
go to the hard drive manufacturer web site , find the down load for you model hard drive and the imac operating system
download and run
Dec 03, 2017 | Freecom (24358) 160 GB Network Hard Drive
Computer crashed and says "Missing NTLDR." I have
Hello, before you do anything drastic, my computer crashed and on reboot said the same thing. After panicking (and a cup of tea), I found the bios had defaulted to booting from the wrong disk. All was ok after I set the bios back to boot from the correct disk again.
Hope this helps!
best wishes,
Dec 29, 2010 | Toshiba Satellite M35X-S149 Notebook
Hello, my name is Thomas, im not quite sure that matters but, i bought a new WD hard drive about 4 months ago, after i bought a 160 GB hard drive a few years back. I'm very pleased with WD hard drives and...
Externals can be a pain. Mainly because of their casings that can cause failures to happen for no apparent reason. If your warranty will be expired and/or the drive is not showing in "Computer Management - Disk Management" I would suggest removing the casing from the external and plugging the hard drive you've extracted from the case into a desktop.
If the drive is still not recognized after being installed into a desktop I would look into data recovery. My personal favorite data recovery software is Knoppix which is an OS(linux) booted from disk.
Sep 26, 2010 | Western Digital My Book Essential Edition...
Advent 4211-c netbook wont load up???????
Have you tried booting in to a Safe Mode and trying to work from there. You can also try using external DVD/CD drive and hopefully it recognize it. Hope this helps.
Jan 03, 2010 | Advent 4211c Notebook
I'm trying to reinstall XP on my sisters viewsonic V1250s and I cant get it to load. I have the recovery cd's and an external cd drive. Her roomate put linux on it and jacked it up. I put in a new HDD and...
> check the disk
Check for scratches on the media.
Also, it could be "bad" RAM in the computer that is creating "random" problems, which could be reported by the B.S.O.D.
If the computer has multiple sticks of RAM, remove one, and try again.
Nov 13, 2009 | ViewSonic Tablet PC V1100
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
Freecom Classic 500GB External HDD Power Problemo
hello Dude ! You have to open the case of that harddisk ,sorry and if the wires are cut from there positions u must solder them back , and put the to its rite position .
in short get ur tool box and have fun
Sep 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Can't Find Hard Drive.
Go into the notebooks bios and see if there is a boot from USB in the boot sequence section. If there is, then enable it. If there is none, then it will never boot from an external drive.
Jun 09, 2017 | Hitachi Travelstar 80 GB Hard Drive
Freecom (24358) 160 GB Network Hard Drive Logo
538 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Trippy Tripp
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
