Question about Dell Inspiron 6400 Notebook
My pc power cord will not charge my laptop but it will run the laptop
    Scholar:
  • 100 Answers
Try this. turn off the laptop and unplug it. remove the battery. let it sit for like 3-5 minutes. replace the battery and plug it in. boot your comp.
go to --
Start -> Contol Panel -> Power Options -> Power Meter and let it sit for a while. Note the battery power remaing. come back in 30 and see if it has gone up.
if not it could be time for a new battery. how old is your laptop
Posted on Dec 25, 2008
My laptop did not power or charge how will i identify the burnt ic
take out the power cord see if it will on battery. if it don't pull the battery see if will run power cord only. see if works either way. see if battery charge light works when plug into power.
Aug 04, 2015 | HP Compaq 6735s Notebook PC
Lenovo idea pad won't charge or run plugged in
Is the cord and Battery the EXACT same power spec? If so, it may be the AC jack in the Laptop has been damaged due to pulling on the cord while plugged in, broken connection.
Apr 06, 2013 | Lenovo IdeaPad Y450 Notebook
I was given a Eee PC seashell.. and they didn't
Dear power cord is use for charging your laptop battery so if you don't use power cord then you will be unable to charge your laptop battery. But this is truth that if your battery charge is okay then no need power cord but tell me bro how can you charge your laptop battery without power cord. This is totally funny. Yes one way, that is you can charge your battery by using dc adapter. But if you do it i am saying you that you just going to spoil your laptop and also battery.
Nov 05, 2012 | Computers & Internet
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
T will indicate charging but it won't charge actor
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 23, 2012 | HP Compaq nc6400 Notebook
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
Dell laptop wont run with power cord and wont charge battery
could be the A/C connector on the mother board this would have to be replaced by a TECH if your cord is good and you have voltage coming out of the end of the cord that plugs in to the laptop then your A/C connector on the mother bord is bad and its a common problem this happens with use, if the laptop is new then return it if not it could cost $120.00 to fix. GOOD LUCK
Sep 21, 2009 | HP Pavilion zd8000 Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Dell Inspiron 6400 Notebook Logo
63 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
