Question about O2 Samsung SGH-E250 Cellular Phone
Can't remove the cover to replace battery
Cover seems to be stuck and is not opening
  • 1 more comment
  • Anonymous Dec 26, 2008
    i have the same problem how do you open it i tried it so many ways and the way the books says but it doesn't work and i dont wanna force it so what now?
  • moniquewylli Dec 30, 2008
    thanks alot...I finally got it open...had to get someone to do it..guess I wasnt strong enough... ha ha
  • Anonymous Feb 12, 2009
    I have the same problem, it doesn't work that way
Hold the phone face down and lengthways in your left hand with the top of the phone at the first set of knuckles (near your finget tips). Then take your right hand and place the base of your palm on the battery cover. Now gradually start to apply pressure with your right hand in a downward and forward direction simultaneously. Wrap the fingers of your right hand over the fingers of your left hand and pull for more control.
And there you go, bobs your auntie.
Posted on Nov 26, 2009
  • Jennifer Henson Jun 23, 2013
    Sillysocks, thank you SO MUCH for your brilliant answer! This phone is my "reserve", so I don't use it very often. I tried and tried, I just couldn't get it open. Neither could my husband, who is usually good at this sort of thing. The picture in the official guide was no use at all. But after reading your excellent, detailed explanation, I got the battery cover off within seconds! I was astounded and, of course, delighted. Many, many thanks to you. I know it's a long time since you composed your Fixya answer, but I'm so grateful that I just had to post this anyway.
Place a small pencil rubber between thumb and phone - you will find that it gives a much better grip. It worked for me.
Posted on Aug 18, 2009
 hey, keep you phone face showing downward. now in the same position keep it in your left hand. you will find a small line which isslightly  upper then surface. now keep your thumb finger (right hand) below the samm line (opposite of the word written as SAMSUMG). Now press with bit force . some force is required to open it.
Posted on Dec 30, 2008
The immobiliser for my Chev Aveo has been activated & I dont I don't know how to bypass it.How can I deactivate/bypass the immobiliser. Im stuck and have no money to pay auto-electricians.
If the battery is dead in the key fob then the following will help you
1. Remove the screw from the back of the cover and open the cover of the transmitter.
2. Pull the transmitter out of the cover and carefully detatch the sticker from the unit.
3. Remove the battery and replace it with the new one. Make sure the positive side of the battery faces up. Use one three-volt, CR1620 or the equivalent.
4. Attatch the sticker and put the transmitter unit in the cover.
5. Put the two halves back together and replace the screw. Make sure the cover is on tightly, so water will not get in.
6. Test the transmitter operation.
Aug 05, 2016 | 2007 Chevrolet Aveo Sedan
Sony t20 battery stuck inside
Open the battery cover, shake the Camera and HIT slowly on the hand by putting the battery side down.
Mar 06, 2012 | Sony Cyber-shot DSC-T20 Digital Camera
My sony ericsson w595 turns off when i flip open it
Hi,the problem you are experiencing with your phone is as a result of a weak flex connector cable.it has to be replaced,here's a detailed solution on how to replace the cable. STEP 1. Tools required: Phillips screwdriver, plastic tool such as a guitar plectrum or credit card.
  • Remove your back cover, battery, sim and memory card.
STEP 2. Run something like a credit card under the metal plate at the top of the phone. It is stuck down tight with double sided tape but it will come away with a little force.
STEP 3
  • Starting near the top of the phone, run your credit card along the join of the front cover. When you have released the cover as much as shown below, slide the cover down to remove it (clips hold the cover on at the bottom which will be bent if you don't slide the cover off).
STEP 4 You should now have the front cover removed. Remove the small screw you can see. STEP 5
  • With the slide open halfway, lift the up the part you've just removed the screw from to reveal three ribbon connectors. Each connector has a black latch which you need to flick over the release the ribbon
  • STEP 6
  • You now have the LCD screen removed. You don't need to go any further if you only want to replace the LCD.
  • STEP 7
  • Remove the speaker and connecting ribbon etc. It's just stuck down lightly. Remove the two screws you can see at the top of the phone.
  • STEP 8
  • You now need to lift the keypad up. It's stuck down lightly with double sided tape. Remove the two screws you can see.
  • STEP 9
  • Run your credit card around the join of the grey part of the phone to release a number of clips. Turn the phone over and release a few more clips in the battery compartment.
  • STEP 10
  • Your phone should now look like below. Two small bezels (shown in the picture) will pop off when you remove the back part of the phone. Now remove the two silver screws you can see.
  • STEP 11
  • You can now remove the battery compartment. A ribbon is stuck to the side of this and will peel away quite easily. Remove the two screws you can see.
  • STEP 12
  • The circuit board will now be loose but still connected by a ribbon. Again, flick the black latch over to release the ribbon.
  • STEP 13
  • Disassembly is complete. Reverse the whole procedure for reassembly.
Apr 21, 2010 | Sony Ericsson SonyEricsson Z250i black...
Shows paper stuck at screen and doesnt have
Have you tried pulling out the whole imaging unit?
Open the top cover and front cover to remove it.
Jan 20, 2010 | Copystar CS-1500 Copier
I removed all screws from the back of my lcd tv to replace minor part and i still cannot pry open the back cover. Seems to be stuck inside the middle.
U sure all the screws are remove.I have taken out many tvs and monitors,all way open.Recheck the middle might have some screws might miss or some covering might cover it.
Jan 13, 2010 | Samsung LN46A650 46 in. LCD HDTV
Its hard to open the battery cover, please help me
Want to change how your Nokia E71 looks? Why not try a different colored keypad or faceplate? Here are photos and instructions which show you how you can do it yourself. Even though it’s simple, I have to warn you to only try this if you are prepared to risk ending up with a broken phone.
For the extra faceplates and spare parts, many people seem to like CNN.CN. They include the Nokia E71’s faceplate, bottom cover and even a whole body replacement. The instructions below will show you how to remove just the faceplate and bottom cover.
I purposely omit the instructions that will enable you disassemble the phone further because the photos just look plain scary.
Release battery cover.
Remove battery cover.
Unscrew four T4+ screws.
Open the two clips.
Do the same on the other side.
Lift the bottom of top cover NOT the bottom cover!
Remove the top cover as shown.
Press out the qwerty keypad.
Remove bottom cover.
Result That’s it! Here’s a sample result from HoFo member rapidstar who replaced the keypad on his Grey Nokia E71 to white.
Dec 17, 2009 | Nokia E71 Smartphone
Dvd player seems blocked
if this is a laptop, remove the drive from the laptop and try to put a paper clip in the little hole in the drive to open it manually, if its a desktop then do the same thing, but u dont have to remove the drive from the computer. if all else fails, buy a new one. a dvd burner in a desktop computer is only 40-50 bucks.
Apr 28, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Installing new battery
sir their is no need to unwrap that cover coz its a paer sheiled of ur battery if u wil remove it ur battery may collapse with metal
Oct 11, 2007 | Motorola Mobility RAZR V3x Cellular Phone
O2 Samsung SGH-E250 Cellular Phone Logo
1,871 people viewed this question
Top O2 Cell Phones Experts
David Burbee
David Burbee
bigb_3m
Level 1 Expert
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
