Question about Nintendo Wii Fit for Wii
WII FIT Board only recognizes movement on one side
  • 6 more comments
  • killerpegg Dec 31, 2008
    when playing certan games on wii fit like the dance in time one and most gym stuff with the trainer it works like left is right and right is left ???
  • pcraig2 Jan 12, 2009
    What can be done if the sensor is broken/not functioning?
  • adhoffman4 Jan 15, 2009
    I did the wii board test and it told me that the bottom right sensor is not working. So can you buy a new sensor? It is under warranty but it was a gift and I don't have the receipt.
  • anderezanav Mar 09, 2009
    I have the same problem! Although it is my right upper sensor that is not working. I already checked and the power button is always facing away from the TV... is there any other solution?
  • Anonymous Mar 15, 2009
    so what do you do if sensor is not working?
    the test showed left bottom not working - how do you fitx it?
  • Anonymous Mar 23, 2009
    but seriously how do you fix it? Take it to a repair person or just but a new one? What the heck do you do?
  • aurorastar24 Apr 13, 2009
    MINE IS UPPER RIGHT TOO CAN IT BE FIXED WITHOUT SENDING AWAY THEY WANT 55 DOLLARS BOUGHT MINE FOR FORTY FROM A FRIEND
  • L. M. Rabalais May 22, 2009
    I am having the same problem. My board is facing the right direction and I just ran a check on the sensors and all are fine. So what else could the problem? I have a cover over the board, but that has not posed any problems in the past. I have only had it for not quite a month. Any suggestions?
    Thanks
  • 3 Answers
Try doing the balance board test to make sure all the sensors are working probably. Click on "User Settings" (the wrench) on the wii fit plaza page. From there your should click on the "wii balance board check." It will walk you through the process and check your sensors to make sure they are working.
Posted on Dec 27, 2008
  • 3 Answers
Make sure that the power button with the blue light is facing towards the back of you, away from the tv. Mine did the sam ething until I switched the board around and now it works perfectly!
Posted on Feb 12, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: Wii Fit does not recognize movement
I called Nintendo and they said there are sensor problems with some of the boards. We had to send ours back, free of charge (they even paid for shipping) and had a new one within 12 days. 1-800-255-3700 is the repair and troubleshoot #....
Posted on Jan 16, 2009
  • 85 Answers
SOURCE: my wii fit balence board is not regerstering my
make sure you are using the proper set up for yourself and not someone elses. For instance if my 70lb son tries to use my settings at about 260lb the board will not read the same.
Also make sure your balanced on a flat floor not some thick or shag carpet that is giving underneath it this will change your weight distribution.
If these are not issues it is possible your batteries are just to low and dont have enough juice to fully function.
Posted on Apr 28, 2010
Wii fit board has a delayed response
check where your motion bar is located and notice your motions in respect to it. If you are too close your motions will be rash, and thus out of sync.... Try backing up your wii fit board and your stance when playing games. This also gives a delayed response... Make sure you are 6-10 feet away from the motion sensor bar...
May 09, 2012 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
These sync settings will be saved even after the console is turned off.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.
Open the SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
Press and release the SYNC button on the console while the Power LED on the board is still blinking.
The Power LED will stop blinking and light steadily once the synchronization is complete.
Mar 16, 2011 | Nintendo Wii Console
We have an intec action board for our wii but don't know how to sync it with our wii because we don't have the directions
Okay, so I played 1 wii game and calibrated the board. Each wii board type of game has a profile creation wizard (mine is wii fit), which guides you through calibrating your movements on the board. Once you have a profile, the board understands the movements as directions or coordinates.
Then you can load your profile when you play the game, not the calibration wizard.
Jan 07, 2011 | Intec Wii Action Board for Nintendo Wii
My Wii Fit hasn't been synced yet, because when I insert a disc into the console, the Wii does not respond. It doesn't recognize the movement of the Wii remote on the screen. What is the issue here and...
do you have the Sensor bar hook at the back. Insert the sensor bar plug into sensor bar connector on the back of the consol.placed the sensor bar above or brlow the t.v screen. SEE if that work and let me know
Jan 01, 2011 | Nintendo Wii Fit for Wii
My wii fit balence board is not regerstering my movements on one side, how can i get this fixed?
Apr 25, 2010 | Nintendo Wii Fit for Wii
Wii balance board weight differently after put on a wii board sk
Sometimes the silicone skin can have an effect on the Wii Fit Balance Board if it gets pinched. Make sure that it is not interfering with the the total movement of the top portion of the Wii Fit balance board and the space between the top and the middle of the unit. If there is any obstruction, refit the skin on the balance board.
Feb 26, 2009 | Nintendo Wii Fit for Wii
Wii Fit - Hoola Hoop
If you're not shifting enough weight to one side, you can't catch a hoop. I have found that lifting the opposite foot off the board as soon as the toss is thrown helps quite a bit.
If you're still having trouble, evaluate how the board works with other activities on WiiFit. If you notice problems in other areas, you may have a defective unit. There is a calibration feature on the program, and if that doesn't work, try opening up a trouble ticket on www.nintendo.com.
Feb 04, 2009 | Nintendo Wii Fit for Wii
Wii Fit instructions for movements are all in reverse
No it is not how Wii Fit is supposed to be. First, let me suggest that you ensure that the power button on the Wii Fit Balance Board is facing AWAY from the TV set. This may seem silly, but it's the most common error. As for the Hula Hoop game, make sure that your weight is all on the side of the Wii Fit Balance Board in the direction that you need to lean to catch the hoop.
There have been instances of the sensors in the Wii Fit Balance Board going out. If you have tried the above steps and you are still getting errors, please go to www.nintendo.com, register your product, and open a problem ticket with them.
Jan 28, 2009 | Nintendo Video Game Consoles & Games
Wii fit does not recognize movement on board. This is a new problem. I've used the board and know how to move on it. Tried new batteries, recharged battery charger, re-synched, help!!!!!!
Sep 05, 2008 | Nintendo Wii Fit for Wii
Wii fit board
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
148
Aug 12, 2008 | Nintendo Wii Console
Nintendo Wii Fit for Wii Logo
1,320 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
