Question about Lionel New Haven Freight Train Set
Lionel locomotive 442 only going in reverse
The locomotive from the holloween train series is suddenly only working in reverse.
2 Suggested Answers
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
Aug 10, 2016 | Crafts & Hobbies
Lionel f7 only runs in reverse
Have you checked to see if the direction switch is on? Most Lionel locomotives can be set to run in one direction by turning the direction sequencing off. This is true for the newer electronic direction circuits and the older electromechanical E-units. Sometimes the direction units fail and the locomotive will only go in one direction or sits in neutral. If that is the case, the direction unit will need to be serviced (mechanical type) or replaced (electronic type). Go to Lionel.com for additional information and help.
Mar 03, 2014 | Lionel Trains Santa Fe Flyer Freight Train...
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
Lionel train problems
Check to be sure that the reverse unit is on. This may be a lever on the top of the locomotive or a slide switch under the engine. If that doesn't solve the problem, you will need to take the engine to a service center to be repaired. A list of service centers can be found at Lionel.com
Dec 20, 2013 | Crafts & Hobbies
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My train wont go in reverse
Try flipping the "Reverse" switch on the bottom rear of the locomotive.
Jan 03, 2011 | Lionel Pennsylvania Flyer Train Set
I bought the 6-30089 Pennsylvania Flyer Train Set last year. It's been in storage in the original box in a cool, dry place since last Christmas. I put it together, but it will not run. There is power to...
Hope you got the set working. If not, look underneath the locomotive near the rear (under the "cabin"). There are two switches, one on either side. One says "Smoke", the other says "Reverse". If the "Reverse" switch was set to "Off" when the locomotive was in Neutral, it will stay in neutral even when the power is cycled or the "Direction" button is pressed on the power supply. Even in Neutral, all the lights will work and I believe the smoke element will heat up but won't puff. Whatever setting the "Reverse" switch is on, try changing it to se if that works. Hope this helps...
Dec 04, 2010 | Lionel Pennsylvania Flyer Train Set
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Forward runs good but reverse dosnt work so good unless you give it a little push but if you slow it down again it dosnt work so good again even siezes. help
You will need to perform the following :
1) clean any and all electrical pick ups (with power off)
2) check, clean, and re lubricate gearing on locomotive
3) check switch on fwd and rev for contact and dust.
4) please note that sometimes this is a really good excuse to buy a new locomotive or upgrade to a BIGGER set.
Hope This Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Nov 29, 2009 | Lionel Trains Classic Freight Train Set
Lionel New Haven Freight Train Set Logo
249 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
