I have hooked up my "plug and play" speakers and still have no sound. My computer keeps telling me that a disc is required. Please advise
  • 4 Answers
Your speakers may be "plug and play" but it seems the sound card is not. You will need to note the sound card make and model and download and install the driver from the manufacturer's web site.
Posted on Dec 25, 2008
Hi i have the Bose Companion 5 speakers for more then a year now i have been playing them for over an hour and just realised that they keep fading the sound goes high and low i have never experienced this...
if you are refering to your computer speakers
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 28, 2011 | Bose Companion 5 Multimedia Speaker System...
My speakers won't play any sounds when hooked up to the computer. I hooked it up to my ipod and it played
im not sure i understand what won't means????????
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 18, 2011 | MidiLand MLi 691PA Computer Speakers
Hi. Today I bought a 3 foot audio y-cable and an RCA (Phono) Female to RCA (Phoneo) Female cable so that I could hook up these two speakers that I have that belong to a predisian sound system (boom box)...
All you need to do is get a USB based sound adapter 16/32BIT MINIMUM to plug your speakers straight into your laptop with better sound. Many laptops will have limited sound OUTPUT which places large limitations on pushing sound through your nice speakers. You already know the problem is not the speakers or new cables, therefore you know that problem has been isolated to your laptop. You may also check the volume settings in the laptop to ensure your running the highest possible BIT or volume enhacement software. Let me know if this does the trick for you.
Jan 09, 2011 | HP Audio Players & Recorders
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
I had a different brad of speakers plugged in. i uninstalled the driver from the old brand and plugged in my Boston BA745 speakers and now ther is no sound// the computer keeps telling me i have no...
U may have un installed your sound card. find your product driver disc that came with your computer and install the sound card drivers. if you do not have the CD, go to the product website that made your sound card and get the relivent drivers.
Hope this helps :)
Dec 13, 2009 | Boston Acoustics BA745 Computer Speakers
I've plugged in two desktop speakers into PC they don't work
The problem is that you haven't installed the proper audio drivers in your system.
Have your audio driver installed and then try to restart your PC.
Oct 08, 2009 | Jwin Audio Players & Recorders
Connecting speakers to Computer
In most cases the woofer plugs into the speaker which contains the power adapter plug, the green plug goes into the PC's audio out (usually a green plug on the back of the unit). When the USB is plugged into the machine the OS should plug and play the new hardware and may ask you to insert a driver disc if applicable.
After the OS has identified the new hardware and installed it you should be able to test additional audio out plugs if you are unable to hear sound from your first choice (again, ideally the green plug). There should also be a line out plug which may work for your purposes also.
If you are still having issues please post the model of your speakers so that we may look them up...
Feb 25, 2009 | Dell Vostro 220 Desktop Computer
Labte pulse 285 speakers!
You won't find drivers for these Labtec speakers because they don't exist.They are plug-and-play speakers so they should work as soon as you plug them into your computer. But I have the same problem as you do (I had to format my comp as well and now I'm screwed because the speakers aren't recognized by the computer).
Nov 02, 2008 | Labtec Pulse 285 Computer Speakers
I am not getting any sound from my center speaker ... please advise.
The movie you have played seems to have been recorded in that way try playing some other movies and see what happens.
Jan 10, 2008 | Wave Audio CS801 Speaker
Computers & Internet Logo
Alun Cox
David Payne
David Payne
