Question about Refrigerators
Defrosting problems The bottom of my freezer is a sheet of ice. I also have water standing in the bottom of the refrigerator. I think it has somthing to do with my defrosting, but don't know how to fix it.
  • 700 Answers
Yu neede to check the drain line that is on the bottom of the coil and make sure that it is draining properly
Posted on Dec 25, 2008
Water in bottom of fridge inside...cant find drain holemodel rf18hfenbww
It is not designed to have water in bottom of fridge so there is no drain hole there. Sounds like you have a stopped defrost drain which is in freezer. When this is clogged with Ice, water from defrosting has no where to go but thru air flow holes from freezer to refrigerator. If this is in fact your problem, you will most likely observe a sheet of ice in bottom of freezer.
Aug 25, 2017 | Refrigerators
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Ice forming at bottom of freezer
I had a problem with Ice forming in the bottom of my freezer on my whirlpool side by side freezer-refrigerator. Turn out to be a plugged drain in the bottom of the freezer. That drain goes into a tray under the whole unit. During Defrost, condensate drops from the contents of the freezer on to the bottom of the freezer and goes through a drain tube to a pan underneath. Should that drain tube become plug and the water is left standing in the bottom of the freezer, it will turn back to ice after the defrost cycle is over. Once the drain tube is clean out, the problem goes away.
Oct 20, 2014 | Whirlpool Refrigerators
Hi I have a 1 year old Whirlpool french door refridgerator bottom freezer with ice maker. A couple of days ago I noticed a thick sheet of ice that formed on the bottom of the freezer. I cleared the ice...
Hello there,
When your refrigerator begins to have ice at the back, it is known as ice build up. There is no leakage anywhere, it is just that there is a component or the other that is being faulty inside the unit of the refrigerator. The defrost unit is where the problem is from.
The defrost process is done automatically and the process involves the defrost thermostat, the defrost heater and the defrost timer. Once one of them or more becomes faulty, ice will begin to form at the back of the refrigerator.
You will have to test the defrost timer, defrost heater and defrost thermostat in order for you to be able to tell which is faulty and need to be replaced.
You can go through these tips if you intend to fix this yourself. Defrost thermostat http://www.fixya.com/support/r10513592-test_defrost_thermostat http://www.fixya.com/support/r10513650-replace_defrost_thermostat defrost heater http://www.fixya.com/support/r10523771-test_defrost_heater http://www.fixya.com/support/r10523754-replace_defrost_heater defrost timer http://www.fixya.com/support/r10523722-test_defrost_timer http://www.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Whirlpool GX2FHDXVD (22 cu ft) Bottom...
Ice sheet forming on bottom of freezer. GE Monogram with top refrigerator and bottom freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | GE Monogram ZICS360NRRH C... Bottom...
I have a maytag bottom freezer refrigerator model#mbf1956keq
apparently its the way the maytag defrosts. I have had this issue since I bought it. FIrst of all, you dont have to go through the whole defrosting process with water on the floor and removing your freezer contents. Simply take a butter knife and from the front corner, slide it under the edge of the ice and the whole sheet can be slid out intact right under the freezer door. I think it had alot to dowith having the humidity switch on, because when it isn't like in the summer when the AC is running, the amount of ice is not that bad.
Apr 04, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Inch of water standing in the bottom of the fridge
The defrost drain hole in the freezer is frozen over causing the defrost water to enter the refrigerator through the air duct.
Turn the refrigerator off. Remove the floor panel and the rear panel from inside the freezer compartment.
Break up and remove the ice you see. Use a hair dryer to melt the ice in the drain trough in the rear of the freezer underneath the cooling coils.
You will see a small hole in the rear center of the drain trough. It must be completely defrosted so that water drains through it.
This will take quite some time to do.
You may want to do the above steps and then just leave the refrigerator OFF for several hours to let the drain hole melt by itself.
Dec 14, 2009 | GE (GTS16BBS) Top Freezer Refrigerator
Water leaking from bottom left freezer/dispenser side
Take the metal back panel off the inside of the freezer, exposing the cooling coils. Below the coils, at the very bottom of the freezer compartment you will find a small drain hole. (Presently covered over with ice) Use hot (not boiling) water and a turkey baster to melt the ice and force hot water into the drain hole until the water runs out the drain hole (and into the defrost drain pan under the refrigerator) on it's own. This should be a Fix-Ya for your refrigerator.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
