Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Bottom right side of screen (about 4 inches high) has blue tint
No matter if watching cable or a movie this is happening consistantly. the bulb is about a year old.
  • Jbrown13302 Jan 02, 2009
    I have the same problem with my Sony Grand WEGA TV. The blue light is on the right hand side and I notice lately that the line is move across the bottom from one corner to the other corner. Please let me know what the answer is to this problem
    Please email me at
    Jbrown13302@verizon.net
    Problem Solver:
  • 5 Answers
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the "Optic Block", ($1300. -not incl labor), that was replaced to fix the problem. That part contains all new LCDs, & multiple Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended).
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have automatic FACTORY extended warranties (up to 10 years), because of some known problems with the blue LCD panels. You might want to contact a SONY office & see if your set is covered.
ALSO - The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Posted on Jan 17, 2009
THE PICTURE ON MY ZENETH PV6067DT TV WILL NOT GET
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
Blue tint on right side of screen.
take it down turn it on the fan may be magnetizing the frame.you may also try running a magnet over the bulb to pull the blue back into its place
Oct 17, 2009 | Sony XL-2200 - LCD projector lamp
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Blue Tint Right side of screen
You have dust on the lcd image plate and about all you can do there is take it too the shop. Unless you have an expensive dust free enviroment and know how to dismantle the light engine...
It's not an expensive fix for a qualified shop - call around and explain what you have here in your post. A good shop will know what this is right away...
Bill
Dec 01, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Blue area near center of screen
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Oct 08, 2007 | Hitachi 50V720 Television
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
