Question about Microsoft Office Word 2003 for PC
I have created a very detailed outline and also a document map using Microsoft Word 2003. Each section of the outline has many indents. For the first few sections of the outline the indents flow correctly, but when the outline gets to a certain point and the indents should start over since I have created a new section of the outline, the same numbering from the previous section continues into the new section and I cannot figure out how to get the numbering for the outline to work correctly (I have figured out how to fix this problem manually by right clicking and choosing restart numbering, but the outline is 55 pages long and it would take forever to fix this manually as the outline is very detailed and has many sections). If possible, I can send the document I am working with so someone can see the problem.
Thank you for your help!
Are you using styles? You could create a new style based on the existing style that has "Start at" and "1" as one of it's attributes. Then whenever you need to restart numbering, just apply the new style. Reply if you need help with styles
Posted on Aug 28, 2009
Nov 26, 2011 | Microsoft Office Professional 2007 Full...
Apr 17, 2011 | Computers & Internet
Word cannot start the converter mswrd632.wpc
This error is cause because of f the security update for Windows XP, Windows 2000, and Windows Server 2003 on December 8, 2009.
You may experience mail merge issues write files are parsed but no message is shown.
To resolve this issue, an affected user can unregister the mswrd632 converter by editing the registry as follows:
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Text Converters\Import\MSWord6.wpc
On the Edit menu, click Delete.
Click Yes.
Exit Registry Editor.
NOTE: For x64 systems above path is slightly changed:
HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\ CurrentVersion\Applets\Wordpad
This change will effectively unregister the converter and disable it
for third-party applications and for Microsoft Office. Microsoft Office
will use its own text converters to open these kinds of files.
You can also fix this issue with applying the registry fix, but that
is a less secure way according to Microsoft, as this fix actually
creates 'AllowConversion' key in the new 'Wordpad' subfolder.
(HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Applets\Wordpad)
Download REG fix
There is another way to solve this issue by copying the MSWrd632.wpc
file from another computer that doesn't have this issue. Make sure that
this file comes from a trusted source on your network. This file can be
found on the following path:
C:\Program Files\Common Files\Microsoft Shared\TextConv
OR DO THIS
Go to Tools > Options > General (Tab) in Word 2003
And check "Confirm Conversion at Open"
When
you next try to open the document it will prompt you with a list to
convert from. Choose Word 2007 and your document will open.
Have in mind that you will have to unregister mswrd632 first, which is noted above, before you make this changes.
NOTE:
If none of this works, please check that your file is not corrupted, or
that you or someone else didn't add X at the end of .doc extension or
vise versa. This WILL NOT work! You have to convert the document using
Office 2007 or 2010.
Dec 06, 2010 | Microsoft Computers & Internet
Nov 03, 2010 | Microsoft Office Word 2003 for PC
Jul 22, 2010 | Microsoft Office Outlook 2003 for PC
Apr 05, 2010 | Microsoft Windows XP Professional With...
Mar 14, 2009 | Microsoft Windows Vista Ultimate Edition
Feb 01, 2009 | Microsoft Office Professional 2007 Full...
Jan 03, 2009 | Microsoft Office Professional 2007 Full...
May 18, 2008 | Microsoft Office Professional 2007 Full...
167 people viewed this question
Are you inserting a section break at, for example, Level 5 and wanting the Level 5 numbering to start over at one. That way it would read Level 1, level 2, level 3, level 4, level 5-1. 5-2. 5-3. 5-4. 5-5. (section break) 5-1. 5-2. 5-3. etc.?
