Question about Panasonic RXD25 Cassette/CD Boombox
Optical unit for RXD25
Please, I want to know the part number of optical unit of Panasonic RXD25 because I need to change it, or if somebody knows a similar unit. Thanks Roberto
  • 30 Answers
I got a website you can go to to find that info "www.partsstore.com"
Posted on Jul 17, 2007
SOURCE:
Have bought a Panasonic soundbar SC-HTB8. No connection cable included. Which cable do we need to buy to connect Soundbar to tv please?
You will need an optical digital audio connection for the TV and the TV will have to be fitted with a compatible "optical digital audio" OUT connection.
The soundbar unit you have does not have an HDMI connection so you only have the one choice with cable..
Any electronics store selling cables will fit you with the correct one.
The one pictured here next to the HDMI cable is the type you need (aka Toslink) but if you don't have an Optical digital Audio Out connection on your TV you have a problem.
HDMI vs optical Which digital audio connection to use CNET
Dec 30, 2015 | Panasonic Televison & Video
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
Let me know how to fix "No Disk" error in Philips DVP 3500. Getting error for all DVD/VCDs. I can see optical moves and lights. Is it the alignment problem or optical..
Typically if your player is over 2 years old the optical unit could be the culprit. The laser unit becomes weak or stops focusing properly. The only go is to change it. Will cost you about 10 -15$ plus labor.
Aug 27, 2011 | Televison & Video
My dvd recorder model no dmr - es15 has troubleshooting with u61. where can i get it fixed
The u61 code is a common code on your unit. It signifies an issue with the DVD controller board. The problem is that it will probably cost more to fix the issue than the player is worth. Some techs had luck with dis-assembling the unit and resetting the optical block. If you have the tools and experience you can take the unit apart, disconnect all of the cables and move the optical block back. The error message is defined as the unit either suffering a power outage or being unplugged while it was on. The unit then tries to run it's own recovery program. More often than not the unit will make some noises, then display a message stating the recovery did not work, and advising you to take the unit to your local Panasonic repair center. Some owners had luck with unplugging the unit for a couple of hours, then plugging it back in and switching it back on.
In closing, if the unit displays the message that it did not recover you can then try and unplug for 2 hours. IF that doesn't work then dis-assemble and move the optical block. Failing that pay for a repair.
These steps should allow you to resolve your issue. If you do have further problems please don't hesitate to let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 24, 2011 | Panasonic Televison & Video
I have a Denon UCD-F07 cd player and it no longer plays cd's . I believe I need a new optical unit for CD-750M drive . the current number on the unit is KSM-2101A. The serial number on the drawer is...
http://shop.euras.com/geraetesuche_new.php?modselect=699489&artgroup=4400000000&&vgl=1&g7=3130732N
Maybe your problem is solved in the meantime, but on this site you can get the optical part for the UCD-F07
Dec 31, 2010 | Audio Players & Recorders
Greenspots on screen
sounds like its your optical engine block. if it starts to leave green spots or white dots that keep on coming then its your optical engine. let me know I know someone who repairs the optical engine block. leave a rating after you find out.
May 08, 2010 | Panasonic PT-52LCX65 44" HDTV
How can I find this optical laser ?? , please
hello somebody help found this optical laser for TASCAM CD-RW 750 . who can i find , what is the number ??? thanks
Jul 15, 2009 | Tascam CD-RW750 CD Recorder
Looking for Filter Unit Optical Number of SONY DSR 390
hi ! i jasdeep working in superb broadcast
can provide the optical filter for your camcorder
Jun 25, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Problem with Tascam Cd-RW750. system error at start up after the "welcome". Then it opens the cd tray and does nothing else.
hello ,, how can i find optical pickup for TASCAM CD-RW 750 RECORDER ,,, what is the number of this optical please somebody help me ,, thanks ,ferr
Jun 07, 2009 | Tascam CD-RW750 CD Recorder
Lens stuck
This kind of lens is not easy to repair. If you are familiar with this kind of technology, try to open and eventually usntuck the optical unit. If not purchase the optical unit part number 178836311. If you need more info please advice. Arpi
Jan 29, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic RXD25 Cassette/CD Boombox Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
