Question about Toshiba 50H81 50" Rear Projection Television
1999 toshiba rear projection tv blinking red light after moving
My inlaws gave us their 1999 toshiba 55 inch rear projection tv for christmas, it worked fine with no problems before moving or ever before that. we loaded it on the trailer screen down on a few blankets and drove it to our house about 8 miles away. i went slow and didnt hit any bumps that i know of. we brought it inside hooked everything up and it wont turn on. the only thing it does is the red power light blinks. its had crystal clear reception and no color problems since they bought it.
  • 185 Answers
This might be a tube leak check for fluid on the necks of the tubes with your hand. if none you might have a faulty protect chip- common-
forgot the exact location but it's on the main board, it's a 16 pin chip as i remember and it is a quad op amp. if you hold your finger across the pins underside it will turn on and stay on as long as your finger is there, if so replace the chip
Posted on Dec 26, 2008
  • Jeramie
    Jeramie Feb 09, 2011
    terrible advice! NEVER put your fingers anywhere on the board while it is powered up. Some capacitors can hold over 500 volts in them and that would make for a bad day.
    The chip you are referring to is z801 and simply running a jumper wire across pin 12 to the ground will help diagnose the problem.
  • A Schneider Feb 09, 2011
    as a toshiba trained certified tech with over 25 years of experience this is a quick and easy
    way for a guy with-out a scope to trace down the fault, no soldering. i suppose you did not notice i didnt say to put a finger across a cap as this would not be advised. as this unit has high voltage present in the tubes in excess of 25 kv i dont advise playing around with the high voltage there either.i assume the reader to use common sense when ever taking any advice especially free advice
My Sanyo tv is not working. The power light comes on and then starts blinking red.
I myself had a 55 inch hdtv ready projection tv and the lamp went out in it. It cost me $104.00 plus shipping to replace it. Check out discount replacement parts but remember that if it is a projection tv, it won't last but approximately two years and you will have to do it again.
Aug 25, 2012 | Sanyo SELECT PLC-XP45 Rear Projection...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Mar 16, 2009 | Sony XL5300 Replacement Lamp for XBR2 SXRD...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 55hx70 projection tv problem
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Jan 20, 2008 | Toshiba 55H70 55" Rear Projection...
MY tV will not power and red light keeps blinking
http://www.keohi.com/keohihdtv/brandspecific/toshiba/quickfix/flashing_led.html
Dec 05, 2007 | Toshiba TP55G60 55" Rear Projection...
Toshiba 55" 55H70 model. Turns OFF, but won't turn ON until I unplug it from the wall first.
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 22, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
245 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
