Question about Hotpoint WMA40 Front Load Washer
The drum does not turn by itself then there are two things which could be wrong. may be the motors brushes which wear down now need replacing because the belt which drives the drum was not broken
  • 640 Answers
Replace motor
Posted on Dec 26, 2008
Fills up but drum does not go around checked belt its fine
Hi dear.
I do not know your machine's model but that may help. When you run a program, after fill with water if you see RINSES LED flashing or drum not rotating,you can check a few things.
1- Motor carbon brushes wear out needs replacing,
2- Wiring between motor to main PCB broken
or
3- Main PCB Faulty.Needs replacing. I hope that helps. Thanks.
Jan 12, 2016 | Miele Washing Machines
BOSH EXXCEL 1200 EXCEL IS HAVING LOUD CRACKLING NOISE WHEN SARTING. THIS IS BEFORE THE DRUM STARTS TO TURN.
It the motor there are carbon brushes in there when they wear down they don't touch commutator... on motor what u here is arcking u shud b able to re place them u will need a model number and make, ..or remove motor and take with u to get right brushes if the moyor is badly burnt u will need to replace it if u continu to use like this it will only get worse
Oct 12, 2013 | Bosch Water Heaters
Drum will not spin but pump runs fine
hello there may be a couple of things that could be wrong 1 check the brushes on the motor 2 plastic blocks sit either side of the motor these are made of carbon and wear down if ok then the other cause could be the module control board this controls the motor speed usually sits at the back of the washer may have a load wire coming off it hope it helps
regards
shaun
May 01, 2011 | Washing Machines
Drum is not turning
Could be the brushes, only way to prove it is to remove the motor and check the brushes for wear.
If they are less than 3 or 4 mm long, then they need replacing. If brushes are o/k, then it is probably a control board fault.
Jun 03, 2010 | Hotpoint WMA54 Front Load Washer
Drum stops turning.If I turn off power and move drum it works for a little while then stops again
I would advise you to remove the motor, and check the brushes in the motor for wear.
If less than 3 or 4mm long, then replace them.
Failing that, then problem could be related to control board or the motor itself, but I would think it is more likely to be worn brushes.
Apr 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Aquarus 1200 hotpoint motor not working
Check the motor brushes for wear.
Replacement carbon mototr brushes available at :
www.hotpointspares2u.co.uk
Regards
Steve - SDA Ltd
Aug 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Problem washer will not wash or spin
If the drum does not turn by itself then there are two things which could be wrong.
1. the belt which drives the drum is broken or come off.
2. the motors brushes which wear down now need replacing.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...about half an hour...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wma40&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
To do the brushes - about half an hour...
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
Jul 08, 2008 | Hotpoint WMA40 Front Load Washer
Bosch WFMC3200
Click on Bosch (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Plug off the wall, open up behind, you will see things.
Pl rate if helped.........
Jan 02, 2008 | Bosch WFMC 3200 Front Load Washer
Hotpoint WMA40 Front Load Washer Logo
83 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
