Question about Coby MPC-848 MP3 Player
I am trying to sync my player with windows media player so I can modify my playlists. Media player says my player is full, but is not recognizing any files located on the player.
    Problem Solver:
  • 6 Answers
My windows media player does the same thing, I just don't use it now
Go to "My Computer"
You should see your Coby device on there
Open it up, you will see the categories where your files are (like Music, Videos, etc..)
Now just simply click and drag ;)
PS: Same with playlists, create one and save it, then find the file and click and drag into playlist folder on Coby
Posted on Jan 01, 2009
How do I put music or videos on it?
You will need to create a playlist on Windows Media Player with your songs, videos, etc. Save the playlist then plug in the Philips GoGear Media Player and turn it on. On top of Windows Media Player find the sync tab and select the playlist you made and drag it to the "Sync List" pane. Then finally click on start sync and you are on your way.
May 24, 2011 | Philips GoGear ViBE Digital Media Player
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
SONY BEAN WONT SYNC MUSIC WITH ITS SONIC STAGE SOFTWARE. with what software can i sync music on this mp3 player
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 30, 2009 | Sony Bean MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Computer doesn't recognize MP3 player -
Don't transfer playlists - only transfer individual songs
Sep 15, 2008 | SanDisk Sansa Clip MP3 Player
Menu
These directions only apply to the Philips SA6045/37:
It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
If you ask me, it's not worth it, but here's the procedure:
  1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
  2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
  3. Click on the Sync tab.
  4. Click on “Sync settings” or “Set up sync”
  5. In the pop-up window, select the playlists that you want to sync
  6. Click “OK”, the sync will start automatically
Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
-Tha Mp3 Doctor
Sep 12, 2008 | Philips GoGear Flash MP3 Player
Cannot load playlists
Try sync your player with winamp. It synced the whole winamp media library (including playlists). Hope this can help.
Jun 10, 2008 | Samsung YP-K3 MP3 Player
Converting Playlists
Use Windows Media Player instead
Feb 28, 2007 | SanDisk Sansa e250 MP3 Player
Coby MPC-848 MP3 Player Logo
56 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
