Question about Radio Communications
PS3 trouble connecting Nokia BH-501 bluetooth headset
Hi there, I followed the obvious steps, but there's no sound in the headset My Nokia BH-501 bluetooth headset is succesfully paired to PS3 and activated as output and input. I can see the PS3 hear my speaking, but I have no sound in the headset? Help THX
SOURCE: Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Posted on Apr 07, 2008
SOURCE: pairing my headset with ps3
forget pass key for madcatz
Posted on Dec 31, 2008
SOURCE: Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
Posted on Jan 14, 2009
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Posted on Feb 20, 2009
  • 94 Answers
SOURCE: No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Posted on Dec 03, 2009
Pairing problem
Means that your headset didnt support such thing.
Jun 29, 2012 | Nokia BH-503 Bluetooth Headset
Nokia bluetooth head set BH-105 can't conect with my nokia C6 mobile
1: SWITCH ON THE BLUETOOTH FUNCTION ON YOUR MOBILE 2: THEN CHANGE MY PHOES VISIBLITY FROM HIDDEN TO SHOWN TO ALL 3; MAKE SURE U HAVE PRESSED THE BLUETOOTH HEADSET SWITCH ON BUTTON FOR AT LEAST 10 SECONDS . 3: U WILL HEAR A BEEP SOUND WHEN THE HEADSET IS SEARCHING FOR PAIRING 4 NOW SEARCH FOR NEW DEVICES ON YOUR MOBILE 5 WHEN THE SEARCH COMPLETES IT WILL SHOW BH-105 6 : SELECT IT AND CLICK PAIR . FINISHED
Jan 26, 2012 | Nokia Bluetooth Headset BH105
NOT CONNECT TO MY MOBILE PHONE
you have to check the compatiblity of this device with yout cell phone.
Connectivity Bluetooth version
  • 2.1 with enhanced data rate (EDR)
Bluetooth profiles
  • Handsfree profile (HFP) 1.5
  • Headset profile (HSP) 1.1
if your cell phone has the above features then follow the undermentioned steps.
you need to search for the device by starting a new search after switching on the bluetooth and make sure that the bluetooth headset BH-104 is switched on.
once the search is completed and your device is found then pair it.
after pairing the device you can use it.
Dec 26, 2010 | Nokia BH-104 Bluetooth Headset
Nokia BH-101 Not Pairing with Playstation 3
Consult user manual for how to put device into pair mode, then search under bluetooth settings on ps3 if prompted enter pin code 0000. If this does not work consult usuer manual for how to do a reset on the device, it should then automatically go into pair mode. From there search and pair.
Rylan
Dec 17, 2010 | Nokia BH-101 BLUETOOTH HEADSET
How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
May 23, 2010 | Nokia BH-104 Bluetooth Headset
My nokia bh 213 bluetooth was working with nokia E63 , all of a sudden it is not , the bluetooth is charged and green light is flickering , when tried to pair thed eivce it says the device not found , what...
Thanks sleekycupid.. Even i had a same problem just followed the steps you said.
Step 1: Switch off the bluetooth device.
Step 2: Charge the bluetooth device.
Step 3: Then hold the device button till the green indicator blinks faster than normal.
Step 4: Now try to pair the device from your mobile.
Step 5: Mobile will ask you a passcode, press 0000 and enter.
You might not follow step 1 and 2. Just start from step 3.
Enjoy!
Mar 13, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Problem connecting headset via bluetooth on PC
You have to press the button to turn it on and hold the button pressed until it flashes red. Then you go in the control panel , bluetooth options, click it , and then go in the find devices options. When the computer finds the device you have to use the option to put your documentation key and use this default number 0000.
Conclude your installation.
May 04, 2009 | Nokia BH-501 Headset
Cannot hear music on bluetooth device from PC
Check your sound settings in Control Panel. If your using Win XP, go to Control Panel, than Sound and Audio Devices. Click the Audio tab and make sure, that under Sound Playback the Default Device is set to something with a "Bluetooth". For me it would be "Bluetooth hands-free audio". You might need to re-pair your BH-501 after doing this.
Mar 15, 2009 | Nokia BH-501 Headset
found devices.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
Radio Communications Logo
864 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
