Question about Canon CanoScan D1250U2F Flatbed Scanner
Scanner not working
Every time I try to scan I get a message (scanner is locked, disconnect the USB cable , unlock the scanner and reconnect)The problem is the scanner is not locked, it only thinks it is locked.
  • 1 more comment
  • KEVBOY Jan 25, 2008
    EXACTLY THE SAME. MOVED IT FROM HOME TO OFFICE, WORKING IT ON THE SAME VP PRO SYSTEM BUT CANT GAT ANYWHERE WITH IT. DOWNLOADED SOFTWARE AS IT WILL NOT ACCEPT DISC SOFTWARE. AT MY WITS END. ITS ONLY DONE A DOZEN SCANS. DISC SOFTWARE SAYS "TWAIN" IS NOT PRESENT. ANY IDEAS PLEASE.
  • draconias Apr 29, 2008
    I am having the same problem with my scanner. It is a visioneer 6200 USB scanner. It sais that it is locked when it is not. These are the exact steps I use before the message appears. I open my paperport program. Then I select the twain option. Now is when the problem starts. If I select the preview option for my scanner the following things happen. My scanner lights up and prepares to scan the image. Then it moves 1/6 in or so under the glass plating until it reaches the lock,(WHICH IS UNLOCKED AT ALL TIMES) as it does so i hear a light grinding noise not very loud but loud enough you can hear it but the scanner has always sounded like that since the first day i bought it and it worked fine then. As the grinding noise fades a message appears on my screen as follows : Please verify that you have unlocked the scanner hardware. The lock is located on the bottom of the scanner. Click OK after you have unlocked the scanner. Then I click ok and try to scan something but i just get the same message again. If anyone can help me it would be greatly appreciated. You can email me, Thanks.
  • AmitabhRox Feb 10, 2009
    Very same with my canoscan lide 25, since I reinstalled it on a new compy.
    I reinstalled the driver many times and changed the USB port .
    Without any luck.
    I didn't get violent so far like the user above , but I might well end up using his method as it'spretty damn annoying for an illustrator >_< lol
Like mine and all of you above the scanner has the same problem of moving a few inches and then the error message disconnect.... unlock ....etc the best solution is throw it in the bin and never buy cannon again. if they cannot come up with a solution that everyone is having with there (approx $200-$300) scaners that dont want repeat business. they wont get if from me thats for sure. good luck everyone
Posted on Sep 29, 2009
    Brigadier General:
  • 6,966 Answers
Hi, there are a couple of things you may want to try. Some of these if not done right might make you loose access to your scanner, proceed at your own risk. 1) really lock your scanner before booting to windows, then proceed to scan, then it will tell you that is locked, follow directions, remove, unlock, plug back, proceed to scan; or 2)use a different USB port (front and back/side); or 3) download and use (preferably new) drivers @ http://alpha02u.c-wss.com/inc/ApplServlet?SV=WWUCA900 or use the CD installer that came with the product. Uninstall your scanner: right click My Computer, Properties, Hardware, Device Manager, look for your scanner, right click, uninstall. or Start, control panel, add/remove programs, remove your scanner programs. You have to reinstall them all again (better with new drivers). Hope this work for you and good luck.
Posted on Apr 24, 2007
Same thing happened to mine, eventually got so annoyed with it I held it upright (so that the scanning array was at the top) then shock it so that the array moved down about 3 inches. Once plugged in again it rolled itself back to the start position and recalibrated itself, job done and all is fine again. Another one for the old 'if it doesn't work, hit it harder' school of thought.
Posted on Apr 08, 2008
I am having the same problem with my scanner. It says that it is locked even though it isn't. I can get the scanner to do a preview scan, but it just shows up black and gray with a vague outline of the picture. Then when i go to actually scan the picture it says that it is locked and needs to be unplugged and unlocked. Any advice would be much appreciated. Thanks
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
I just installed my new Canon LiDE 110 scanner. I slid the lock button to the unlock position. When I try to scan, I get the following error: "Release the lock switch, detach USB cable and...
mbrindle is great!!!! Many thanks - I was just about to take it back as I thought the scanner was defective. Would never have thought i had to do that. Thanks!!!
Aug 15, 2011 | Canon CanoScan LiDE100 Flatbed Scanner
Hello I am having problems saving my documents I am receiving an error message "Release the lock switch,detach usb cable and reconnect.Close the scanner driver .What lock switch is this ?please advice...
-is this a new scanner? is this the first time you are trying to scan?
if you answer yes to any of this questions, please check underneath the scanner, find the latch to release the scanning head.
Dec 16, 2010 | Canon CanoScan D646U Flatbed Scanner
Scanner showing error 04 and cant let me scan
Disconnect the power supply from the back of the scanner base.
Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
Reconnect the power supply and turn on the scanner.
Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
now try to scan the document ..........
Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
Message received Release the lock switch,detach the usb cable and reconnect. Tried this but it doesn't work. The scanner is not locked!
Uninstalled software, disconnected usb cable. Then reinstalled software and reconnected usb cable.
All up and running!
Nov 23, 2009 | Canon Office Equipment & Supplies
Canoscan lide 20 Error; Release the lock switch, detach the USB cable and reconnect. Scanner driver will be closed.
hi.. there is a lock under the scanner you need to unlock it... lock it to prevent damage while transporting...
Dec 16, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Nov 19, 2008 | Canon CanoScan 9950F Flatbed Scanner
Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Jan 04, 2008 | Epson 2580 Perfection Photo Scanner
Awful noise
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Canon CanoScan D1250U2F Flatbed Scanner Logo
724 people viewed this question
Clive
Clive
old marine
old marine
