Question about Lexmark Z735 InkJet Printer
There's a pencil stuck in my Lexmark x5450
How do I get a pencil out of my Lexmark printer? My daughter was trying to get a sheet of paper out of the paper tray and she dropped a pencil inside. We tried to get it out and it worked its way further in.
Shaking it doesn't work. Do you have any suggestions?
Thanks in advance,
Sherri
    Scholar:
  • 100 Answers
Hmmm... try lifting up on the scanner part to open, like you are going to change the ink cart. might have worked its way in there thats about the only reasonable entry point i can think of. and please try not to shake it more than you have to. they dont like that :)
Posted on Dec 25, 2008
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Sticking paper
Do not use recycled paper in this machine if you can. I would also try to fan the **** of paper before installing it in the machine.
Aug 02, 2010 | Lexmark Office Equipment & Supplies
Hi, my lexmark x2600 paper load light keeps blinking. I think my daughter was messing with the buttons.
Try to remove all sheets of paper. Then unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet in the wall. Wait at least 30 seconds before plugging back the power adapter in the printer. When the printer's ready, load some papers and check if it's working fine now. Keep me posted by leaving a comment. Thanks.
Jul 08, 2010 | Lexmark X2600 InkJet Printer
My Lexmark C510 printer will print one sheet fine and then give me an error, "201 Paper Jam, Open Rear Door". If I turn the printer off it will reset and I can print one sheet again and will get the same...
there is small Plastic sensor on the paper path, is stucked or broken, is giving this error, need to look closer and check if anything is stucked (paper or dust)
Dec 28, 2009 | Lexmark C510n Laser Printer
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
My Lexmark all-in-one printer which I've had less than 2 months, began making a horrible noise and perforating the right side of paper.
Hi, If you are having this kind of problem so soon after buying the machine I would take it straight back and either get a replacement or a different machine altogether.
Nov 21, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark Z735 InkJet Printer Logo
103 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
