Question about Whirlpool RBS275PD Electric Single Oven
Oven will not heat since auto clean
The oven will not heat up since we used the auto clean option.
  • 1 more comment
  • Anonymous Dec 31, 2008
    No, but mine quit working on Dec 27 after self cleaning!!! I am going to try and get a new fuse and have my electrician put it in for me.
    I did see another post somewhere that this was a recall issue with this model and that the person got hers fixed for free. Wonder if that's still available?
  • athome2 Jan 31, 2009
    I have owned my oven for 7 years and for the first time used the self-clean. Now my oven will not heat up. Lights come on and fan blows, but no heat.
  • dmcarp Mar 01, 2009
    I used the self clean cycle & now my oven will not heat
We had the same problem, only we discovered it on Christmas Day
The problem is the thermal fuse/thermal cut off, the new part # is 9759243-old part#4451442 you have to cut the power to the oven, remove the oven from the wall, remove the back panel, take off the old thermal unit & install a new one. We paid $41.06 for the unit.
If it were not for this sight we would have gotten an electrician & paid a minimum of 175.00 which would have included the person coming out, ascertaining the problem, getting the part coming back etc.
We are back in the cooking business!
Hope this helps, and thank you all for your input.
Posted on Jan 02, 2009
Why when i used the self cleaning option on my upper oven will it not heat anymore?
Good Morning James,
I understand you used the self-clean option on your Frigidaire oven, model# FPET2785KF, and now the top oven will not heat. I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "set clock" button, entering in the time, then pressing the "start" button. Set the upper oven for any cycle at any temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your wall-oven status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Professional 27 In. Stainless...
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
heatman101
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
I used the self cleaning option and cleaned the oven now that the cleaning process is complete the oven will not heat up. the clock/timer just above the oven door works but it will not heat up at all. What...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Electrolux wall oven not heating after self cleaning -- fan is going -- but it is not heating
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
May 17, 2010 | Ovens
I used the self clean option and now my oven will
There is a thermal fuse inside the rear panel of the oven that frequently blows when using self clean option. This is where I would start looking.
Sep 30, 2009 | KitchenAid KEBC101 Electric Single Oven
After using self clean oven will not heat on any setting
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 17, 2009 | Whirlpool RBS275PD Electric Single Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
Whirlpool RBS275PD Electric Single Oven Logo
289 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
