Kenmore calypso washer machione fills up with water but then drains asap runs a littlebit but dry, no water. any suggestions for this
  • 640 Answers
Drain hose to low,,sphion effect,,raise drain hose height of unit befor going down...make sure unit is not coupled to the wastes pipie without air gap,,sphion effect
Posted on Dec 25, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso fills with water doesn't wash or drain
EITHER THE RELAY FOR THE PUMP IS OUT OR THE PUMP IT SELF IS OUT.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso won't run can't get tub to drain water
you need to clean or replace your pump more than likely there is something caught in the pump
Dec 20, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
