Question about byD sign 2012 20 in. HDTV-Ready LCD Television
I am looking for the code for a TV by D:Sign
I have an under the cabinet kitchen TV by D:Sign. I need to program my Direct TV controller to this TV but the D:Sign manufacturer is not listed in the TV manufacturers on Direct TV. What is the code or how do I program the Direct TV controller for this TV
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
I need the code list to program my big button remote. My brand of TV is Insignia
Big Button remote control have pre-programmed with 3 digit codes. There are no code for Insignia tV with it. Codes for this TV are:
0103 0189 0217 0135 0133 0116 0167 0456 0029
Anyway try a code search method. Some times, ti might help you.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Jul 16, 2012 | Big Button TV Universal Remote
How can i program a universal remote control for my sylvania tv?
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
Jun 16, 2012 | Sylvania Televison & Video
There is no mode button on remote
Try a code search method. If there is any pre-programmed codes for your TV is stored in the remote, you can win.
Jun 10, 2012 | Televison & Video
How do you program the remote URC60231-00R01 3RC32B-1167
Direct Code Entry
Code Search
REMOTE CODE
[ http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1 ] Please copy this web page link and paste it into the address bar of your web browser. This web link will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using Fix Ya and have a nice day.
Jun 06, 2009 | RCA DIRECTV Satellite Remote Control
Can't program it to a Philips Magnavox Tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p] Please copy this web page link and paste it in to the address bar of your web browser. The link will take you to the RCA customer support web page with the instructions for programming the remote control and will have the remote codes needed for using the remote control with your television. Just look for the codes under the TV listing on the page. I hope this information helps you the problem you are having with the programming of the remote control for use with your television. Thank you for using FixYa and have a nice day!
Apr 25, 2009 | RCA DIRECTV Satellite Remote Control
Codes to program Innovage Products Jumbo Universtal Remote
I need the code for my rca tv so I can program the inovage jumbo universal remote Pleaseeeeeeeeeeeeeeee
Dec 31, 2007 | Televison & Video
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
byD sign 2012 20 in. HDTV-Ready LCD Television Logo
48 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
