Question about HP PSC 1315 All-In-One InkJet Printer
Printing an 5.5 " by 8.5 " announcement on my inkjet printer
I have announcements I am trying to print up. I set up my HPPSC 950 for 5.5" by 8.5" paper. I load the paper in the paper tray on the right hand side as it enters, but it keep printing as if the paper was in the center. I have tried everything to correct this, but to no avail. How do I get it to justify or aling to the correct side for that size paper?
    Problem Solver:
  • 35 Answers
Dear Sppamelot You did not write the software name, in which you are working. Place / open your document in word, coreldraw or pagemaker, photoshop or adobe reader. Put this document exectly in page shown on your screen, where you want to print. Size dosn't matter. it will print exect that place, where you have put it.
Posted on Sep 24, 2007
Why when I select Glossy in the print settings, the print shifts?
Run this paper from the bypass tray located on the right hand side of the machine.
Try setting that paper type on the copier itself.
Load the paper. Go to the manual paper tray select screen. Select tray 1 and then change paper settings.
Glossy paper also tends to slip in these machines when the paper tray rollers are bad.
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
My new hp 2035n printer give an error when i try to print. the error says: load paper to tray 1
Instructions Things You'll Need:
  • Inkjet printer
  • Labels
  1. 1
    Prepare your printer. Make sure the power is on and the drivers are installed correctly on your computer.
  2. 2
    Wait for printer to stop. Make sure your printer is idle or ready or waiting for paper to be loaded. Don't load labels when your printer is already printing or running an operation.
  3. 3
    Prepare your labels. Make sure they are all facing the same way and are right side up. The label side should be face up. Many labels have an up and a down as well, look for a "this side up" or "load this way" indicator. Or take a look at the print preview before you print and make sure your labels will be fed correctly.
  4. 4
    Find the correct paper tray. Some printers have manual feeds and automatic feeds. Refer to your manual to find out which one you should use for labels. If you are going to use the manual feed, follow the manual's instructions. However, most printers will use the automatic feed, so read on.
  5. 5
    Align the paper guide. This is a moveable piece on the paper tray. There should be markers for the width of your paper. Standard pages are 8.5 inches. Move the marker so your labels will fit.
  6. 6
    Load your labels. Place your labels in the tray so it touches the immoveable side of the paper guide. Slide the paper guide over to touch the other side if it is not already close. Do not bend the labels by pushing in too far.
  7. 7
    Find the paper thickness lever. Try looking under the door that lets you change the cartridges. Or search around on the back or side. Check your manual, too.
  8. 8
    Set your paper thickness level. Usually you'll use the standard size. However, your printer may need to use a thicker setting. Check your manual.
  9. 9
    Change your media type. In your printer settings, find the media type option. You can access settings by clicking properties or settings on the print dialog right before you print. Select "labels."
Oct 02, 2010 | HP P2035N LaserJet Monochrome Printer
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    I am trying to print onto 5.5w x 8.5h invitation paper. What settings do I need to use? If I select the paper size and put it in the printer, it will not print .... expecting regualar size paper.
    Have you tried the upper level tray of your printer?
    Go to the Print command
    Select Properties
    Go to paper source
    Select upper tray (Be sure tray is loaded with paper)
    select OK,
    select OK
    Jul 14, 2009 | HP PSC 950 All-In-One InkJet Printer
    Microsoft Word displays the following message on the screen: ?Printer out of paper.?
  • The paper trays are empty or overloaded.The paper is curledThe print side, or shiny side, of the paper is not loaded in the input tray face down.The paper might not be engaged with the feed rollers.The paper-width guide is pressed against the paper stack too tightly.The paper tray is not completely inserted into the product.The paper settings in the print driver do not match the paper loaded in the paper tray.The rubber paper-feed rollers are coated with dust.
  • Check the media and print settings
  • Clean the rollers
  • try this. have a nice day.
    Apr 30, 2009 | HP LaserJet 1320 Printer
    How to print an envelop
    nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
    • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
    • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
    To Load a Single Envelope
    1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
    2. Remove a single envelope from its packaging.
    3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
    4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
    5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
      NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
    To Load Multiple Envelopes
    1. Slide the paper width adjuster to its leftmost position.
    2. Pull out the paper length adjuster and remove any paper from the IN tray.
    3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
    4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
    5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
    6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
    7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
    Set up the Printer Properties
    1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
    2. Select the Paper or Setup tab depending on the version of the printer driver software.
    3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
    4. Click OK.
    Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
    1. Remove any remaining envelopes from the lower (IN) tray.
    2. Slide the paper width adjuster to its leftmost position.
    3. Load the desired paper into the lower (IN) tray.
    4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
    5. Select the Paper or Setup tab depending on the version of the printer driver software.
    6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
    7. Click OK.
    Jan 19, 2009 | HP LaserJet 1600 Printer
    Trouble printing envelopes on kodak esp3 printer
    Have you tried this procedure?
    Loading Envelopes
    You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
    Important Do not use envelopes with cutouts or cellophane windows.
    1 Remove any other paper from the paper tray.
    2 Insert one or more envelopes into the right side of the paper tray with the print side down and
    the envelope flaps on the right, pointing left.
    3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
    4 Leave the paper tray open while the envelopes are loaded.
    If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
    Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Error message unable to print
    1.The printer is asking you to manualy load the right size paper.
    source tray possibly tray 1
    2. The printer has finished printing the first side of a manual-duplexed job and is waiting for the pages to be reloaded so it can print the second side. Reload the pages.
    3.you are trying to print to the source (tray) and there is no paper in the selected tray. laod paper trays.
    4. The print image is larger than size of paper in the tray. Load the right size paper. Press go Button
    Jan 02, 2009 | HP LaserJet 2550L Printer
    Cannon mp780 paper pulls to right hand side and jams everry time
    printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
    clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
    Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
    Only wants to print out of tray 1
    paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
    Nov 30, 2007 | HP LaserJet 4350 Printer
    HP PSC 1315 All-In-One InkJet Printer Logo
    124 people viewed this question
    Clive
    Clive
