Question about Dell Dimension 8400 power supply ** FREE ** (D8400SATA300W24PINB) Power Supply
Have a yellow amber light blinking
Hello have a yellow amber light blinking on dell 8400 dimension computer was working last night came in to use this morning wouldnt turn on unplugged powercord for awhile turned back on still same problem checked dell solutions to problem still no change. checked all the connections in computer that dell suggested to check no luck system lights on back of computer arent lit up either.
  • Dell Master
  • 998 Answers
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Dec 26, 2008
But <?????
if you do not have time to correct your spelling - go be a artist or mime. Accuracy counts in everything - especially computer problem solving.
buying a new one / or bought a new one, is NOT a valuable solution to anyone.
Posted on Mar 07, 2010
    Problem Solver:
  • 5 Answers
But a new one
Posted on Aug 27, 2009
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
If the power light is blinking amber -
The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 8400 Won't Boot Up
call dell first tell them the problem,they should help you,or use chat i use that sometimes.
Apr 18, 2009 | Dell Dimension 8400 PC Desktop
Dell pc dimensio 5150 wont boot up
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Feb 14, 2009 | Dell Dimension 8400 PC Desktop
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Computers & Internet Logo
954 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
