SOURCE: pentair Mini Max , no power to igniter.
you may have to reset your board.turn all power off to the unit then turn it back on.if this doesn,t do it make sure you have a good complete circuit from board through element then back to ground.
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
SOURCE: Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
