Back to:
Tags:
Nokia HS-23 Headset
Need help for hs-23 headset repair (by 7 users)
posted by ammu on Apr 16, 2007
my HS-23 stereo headset had accidentally got plucked off and totally disconnected from the soldering of the middle section. I checked all the wires in the headset using continuity tester and I found all were working. I just need to solder the wires that has been plucked off from the mic switch but the problem is that I am unable to understand which color wire should be soldered to which point. Could you please help me out which color wire should be connected to which terminal in the mic switch case.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on Jun 24, 2008
enroscou o cabo e soutou as soldas do cabo! pode me ajudar com o diagrama eletrico
Comment by Guest, posted on Apr 28, 2008
i have nokia headset-23,accidentally the the wires have been plucked off, how i can shouldered it, want to know about the colours and the connection diagram
Comment by Guest, posted on Apr 11, 2008
All the pieces of wires is been remove from the bottom end of the headset
Comment by PPNPPN, posted on Mar 12, 2008
Comment by Guest, posted on Mar 09, 2008
user instructions
Best Solution
posted on Jun 08, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In this middle section, the wires are as follows: MIC+: Yellow MIC-: Black L+: Blue L-: Copper/Grey Stripe? R+: Copper R-: Copper/Grey Stripe? (same as L-, they should be interchangeable...) Sirial?: Yellow/Orange Stripe Uout: Red GND: Green Hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on need help for hs-23 headset repair:
I don't want to Accept this solution
Solution #2
posted on Jan 18, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
Buy other.
Thank You!
Can you Help with these Headsets problems?
Headsets
What causes dropped calls in an office? It's very spuratic...
Headsets
i have a new headset and mic but the colors are diff from...
Nokia HS-23 Headset
i used my cable only for 5 days .. i accidently pulled it...
Nokia HS-23 Headset
my hs 23 headset got separated in that part that goes over...
Nokia HS-23 Headset
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 08, 2007
Loading problems.
Repair Service
Find Headset Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
