Question about Panasonic PT-47WX49 47" Rear Projection Television
PT 47 convergence IC's? box? both?
Well there seem to be a lot of people recently with the same problem as mine so I've got an idea as to what it is. I've done the "POWER/ACTION self-check reset" the unplugging and found the tech menu (which was impossible to read on the screen so couldn't do anything with it). The self check tells me all systems are OK. The problem is with the green when trying to set the convergence using Convergence 1 the horizontal line in the "big green cross" is high and can be moved but not to where it should be it also is a bit wavy, the vertical line is a bit distorted at the top and progresses to not even making it to the bottom of the screen. Moving on to the next screen (lining up red, blue, green in the middle of the screen) the green cross is high to the point where I can line up red and blue and the very top of them is only the bottom of the green horizontal line. Convergence 2 is fairly impossible to deal with maybe getting one cross to line up if any. Needless to say the picture has everything with a headache inducing "green ghost" effect. This would lead me to believe I need to replace my IC's. But I also have an "hourglass effect" going on with the green. The bottom of the screen when watching something has a curved band of green lines above this is where the "ghosting" comes in below it things are clear and oviously just the reds and blues. The top of the screen has a bit of this but it's not as pronounced. I saw this problem elsewhere up here and the suggestion was the digital convergence box. Don't know which one I should look into first so any help would be appreciated (and yes I'd love to have the tech manual emailed to me!!). Also would appreciate the best place to look into getting the parts needed to fix this up. Thank You Very much!!
  • Brian Kriley Apr 21, 2007
    Thank you joshv one more question if I could. The IC's are 392-110's but I've been reading that may people "upgrade" 110's with 180's. They seem to be a little less prone to failure due to heat etc. if this is true sounds like a good idea for a few more bucks. Also have read that if you replace the IC's its a good idea to replace the fusible resistors around them because they are likely to fail if the chips fail. True?
I seem to be having the same problem as Silentq2... Just browsing these boards makes it seem like everyones panasonic tv's are all going bad about the same time.. strange..
Posted on May 12, 2007
Sears has tv parts. I was able to get my convergence ic within a week from them.
Posted on Apr 22, 2007
  • kat Griff Apr 22, 2007
    I got mine from sears and had it within a week. Should have bought 2. Mine for a maganovox was 35 + 12sh
    Scholar:
  • 77 Answers
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Posted on Apr 21, 2007
  • josh vannoy Apr 23, 2007
    the 180's are rated a little higher and what your saying is true in theory but I have had some trouble a few times where they just don't seem to work, they will either go again fast or not let the TV align quite right. So I don't mess with trying to sub, but I do this job at least a couple of times a week it would probably be fine in your tv. check the fuseable and resistors, they're either bad now or will be fine in the future
Engine accelerates very slow has power in upper rpm range and no power off idle
any codes will help, but cheking your fuel press regulator its a good idea, remove vac. hose and check for fuel in it, replace if found faulty.
Jul 21, 2013 | 1996 Toyota Camry
Drilling out screwheads, not screwing the screw in!
Sears has a great easyout bit setup. They work great for getting stripped screws out.
Jun 01, 2017 | Drills
2003 Mitsubishi Diamante, power loss
If your car idles and runs smooth after everything you've done, I would almost say clogged catalytic converter just by the power loss.
Jul 19, 2012 | 2003 Mitsubishi Diamante
How do I bypass the power on password on my recently resurrected Armada M700 (it's to be a gift to my granddaughter)? I've done all the battery disconnect stuff and waited an hour after...
Resetting password & user name: b>*Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Sep 19, 2011 | Compaq Armada M700 Notebook
Dyson is making a higher pitched sound than usual. I do not see blockage in tube, but seems to be when it switches from wand to regular in the curved transition area that I can put my hand over the wand a...
Sorry to hear you're having difficulties with your DC25. Although I note you've mentioned that you can't see a blockage, you might find it helpful to follow these steps from our online guide, just to make sure you haven't missed anything:
http://www.dyson.com/support/help.asp?article=1148&product=DC25-ALLFLOORS
Also, you might find it useful to watch this video guide showing the correct way to remove, wash and replace the filters, to make sure you've fitted them correctly:
http://www.dyson.com/support/help.asp?article=1457&product=DC25-ALLFLOORS
If you've tried this and are still having issues, please get in touch with us directly, so one of our experts can determine the cause of the noise and suggest the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson DC25 All Floors Bagless Upright...
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
Mar 12, 2017 | HP Wireless Optical Mouse
2000 Yamaha XJ 900 Diversion. I've got an engine noise that seemed to have come on quick. It appears to be coming from the top of the engine. It sounds like a shaft running in dry bearings. Any idea what...
Have you had it serviced lately?? Is the oil the correct viscosity?? Have you changed the oil filter recently?? Mine went slightly noisey when I replaced the oil and filter, The oil I used was too thick, I`ve got 10W 40 in now, It`s run great since I changed it in April. Touch wood. Ian
Apr 27, 2009 | 2000 Yamaha XJ 900 S Diversion
Digix Ht-1056A Chapter Pause Problem
Tu home theater tiene karaoke integrado? Si es as?, ve al menu del aparato, dirigete al submenu audio y apaga (off) la opci?n "Semi Karaoke".
Eso deber?a de resolver tu problema ya que es com?n en algunos modelos LG con karaoke integrado.
Sep 14, 2006 | Digix HT1056A 5.1 Channel DVD-Home Theater...
Panasonic PT-47WX49 47" Rear Projection Television Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
