Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error message inner cover is open canon pixma mp610 printer
Ok, so here I am in the installation process when after about 2 minutes into the alignment process I get the message above. So I did indeed open and close both covers--started all over again, got the same message. Next, I turned the machine off and began again--got the same error message. Next I turned it off and uplugged it, began again, got the same message. The cover fits just fine, there's no obstacles--what gives--I sure hope I don't have a lemon... I have the same problem with the inner cover open message.......what gives??
  • 4 more comments
  • py72 Jan 03, 2009
    I have the same problem – after changing four empty cartridges I suddenly got this error message. Nothing seems to help (not even a firm fist on the cover like we used to do with televisions back in the 1980s).
  • Anonymous Jan 19, 2009
    I have the same problem.
  • Anonymous Feb 08, 2009
    Inner cover is open ......but it is closed
  • BRIGFRITZ Feb 16, 2009
    I've tried opening and closing both covers numerous times but am not getting a different result...keep getting the same error message
  • Anonymous Mar 31, 2009
    Ncos .... THANK YOU. Googled the error and found your solution.
  • Anonymous Apr 28, 2009
    good work ncos !!
Had the same problem myself but discovered that I had previously moved the inside flap down when I put the ink in. I moved this back into position and bingo! (If you make sure all the covers are closed then look into the printer where the paper exits you will see the flap that moves up and down, this must be in the up position)
Posted on Jan 31, 2009
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon Pixma MP500. Everytime I try to print, I get an error message that says the inner cover is open, but it's not. I've turned the machine off, unplugged it, confirmed the cover/flap is up and...
Hello sir;Lift up the inner cover , on the right hand side there have a round hole look down the hole you will find a piece metal, try find some stick to push down that's door switch, if the message disapear, means door switch is OK, then have make sure your reset procedure is correct, close all cover turn switch off , UNPLUG power cord, wait for about one minute plug in and turn on the power again, it should be work.
Feb 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Inner cover of printer MP610 -error 'inner cover not closed'
I am still on . Get back if your problem is not solved.
Aug 03, 2009 | Canon PIXMA MP610 InkJet Printer
Inner cover is open
Hi there.
There have been hundreds of complaints about this problem. You can download a driver AND a user manual from the first link listed below. The second link will take you to a really great site for your printer.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11995#DownloadDetailAct
http://damnprinter.com/96/tray-guide.html
Jul 31, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error message that inner cover is not closed when it is
hello, please turn off the printer and turn it on again. If this doesn't help, check that the inner cover is fully opened, and that nothing holds it. If the same problem persists, you should take it to a repair center.
Jul 29, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mp600r - reporting inner cover open
unplug the printer from the electric...that should reset the error message.
please leave a rating for me...
May 15, 2009 | Canon PIXMA MP600R All-In-One InkJet...
On cannon pixma mp610 printer messge on the printer says inner cover is open.close inner cover and press ok. I did that and pressed reset and still get this message. Cover is closed and I cannot get the...
try to reset the printer, power off, remove the main supply cable, leave it for 1 minute... and restart the printer...below link might be useful for more troubleshooting tips..
http://etech.maiila.com
Nov 01, 2008 | Office Equipment & Supplies
Just got a canon pixma mp970 printer and it keeps saying that the inner cover is open.
On my MP610, you have to look inside from the front of the printer to see the inner cover. It's a cover you have to open to install ink cartridges. It took me a while to figure it out on my printer too. They'd save a lot of headaches by putting a small identifying label on the inner cover.
Aug 15, 2008 | Canon MP610 Photo All-In-One Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
4,292 people viewed this question
old marine
old marine
